Welcome to the North American Subaru Impreza Owners Club Thursday March 26, 2015
Old 06-26-2012, 01:25 PM   #1
token85
Member#: 105974
2002 02 bug eye
05 blob eye
Default noob mistake, please help
My noob mistake was i didnt mark any of the vacuum lines as i pulled them off. I am swapping a ej207 V8 into my bug eye, and i came across 2 vacuum nipples on the intake manifold and i dont know where they go to. Thanks
One is this one, its a line thats under the t/b on the intake mani
second one is the side one, i think it might be the brake booster line.
Justin
token85 is offline   Reply With Quote
Old 06-26-2012, 03:20 PM   #2
token85
Member#: 105974
2002 02 bug eye
05 blob eye
Ok so after looking at some figures from a maintenance manual, the large nipple is for the brake booster, im still not sure about the one below the t/b. Also i think i may have posted this in the wrong section. If a mod see's this can it be moved to the 2.0 section. That might be a better section. Thanks.
Justin
Old 06-27-2012, 04:38 PM   #3
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
The line under the throttle body is for the bypass valve (or blow off valve if you're not running the factory valve).
The big nipple is definitely for the brake booster.
wrx_driver_2002 is offline   Reply With Quote
Old 06-29-2012, 04:37 AM   #4
token85
Member#: 105974
2002 02 bug eye
05 blob eye
Thanks! So the line under the t/b is the vacuum line that goes to a stock bov? i plan on doing a front mount with stock bov, i hope it works.
Old 06-29-2012, 05:32 AM   #5
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
ha, you have the manifold on backward if you doing a stock installation- install.
If your doing a reverse manifold, run a long tube from brake booster to big nipple.
the brake booster (big nipple) faces the drivers side fender well. It connects to the brake booster.
MY EJ20TTTTTT is offline   Reply With Quote
Old 07-14-2012, 03:47 PM   #6
token85
Member#: 105974
2002 02 bug eye
05 blob eye
Thank you. I ended up tapping the a hole for the brake booster nipple so i could use the stock hose.
Help! noob mistake subbiechronic Newbies & FAQs 23 03-01-2011 04:24 PM
suspension noob here please help token85 North West Impreza Club Forum -- NWIC 7 03-16-2008 11:03 PM
some noob questions please help vrgs AccessPort 1 11-11-2007 10:37 PM
Noob Question please help?! yournamehear119 UTEC 2 02-14-2007 12:33 AM
noob question! please help simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-31-2006 02:00 PM
