Old 08-29-2002, 08:33 PM   #1
2.2gotboost
Member#: 22860
Default Turboxs Stage 2 Unichip HELP
Does transmission matter in the programming of this? Is one of these worth 500.00? Can iI use this until I can get the turbo back exhaust? Any help appreciated.Thanks.
2.2gotboost is offline   Reply With Quote
Old 08-29-2002, 10:30 PM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: Turboxs Stage 2 Unichip HELP
The transmission doesn't matter. The price is probably going to go down as UTECs replace them.
You need the adjustable boost controller, the harness and the Unichip and it does help a lot. You should also have a boost gauge for setting the boost. If you turn the ABC all the way clockwise it is in the most safe boost setting. Then you can add a boost meter and raise the boost by turning the set screw counter clockwise
But you should have TXS change the map from stg 2 to stg 1. The stg 2 setting is more rich than it should be for stg 1, but you can run it.
You should get a lot of bang for the buck in performance with a mod that takes about 20 minutes when you know what you are doing. Click on WRX and you can order the ABC if you don't have it. The installation instructions are on the TXS homepage.page
Now that I have ordered a UTEC, there will be one more Unichip on the market.
z&cobb is offline   Reply With Quote
Old 08-29-2002, 11:46 PM   #3
2.2gotboost
Member#: 22860
Thanks alot for your input.
TurboXS Stage 2 Unichip WRmotoX Private 'For Sale' Classifieds 7 10-27-2003 11:25 PM
NY: TurboXS Stage 2 Unichip and Harness Bask Oner Private 'For Sale' Classifieds 0 10-19-2003 01:50 PM
FS: TurboXS Stage 2 Unichip LehighWRX Tri-State Area Forum 0 01-13-2003 12:57 PM
TurboXS Stage 2 unichip on car with different setup... OK? rlavalle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-15-2002 03:42 AM
