Old 06-26-2012, 11:26 PM   #1
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
Default Subaru conversion in a Radical SR3 (version 8 Spec C)
A local customer decided to ditch the problematic Hayabusa engine in his Radical SR3 for something with more power and cheaper maintiance costs. Based on the flawless performance and reliability of the EJ255 powered Boxster that we finished up a few months ago, the decision was made to go with a similar drivetrain. We are going to be using a Porsche Boxster 6 speed transaxle (G86/20) and a JDM version 8 Spec C engine.
This is what started it all...
The new engine. A JDM STI version 8 Spec-c engine.
Empty Radical "engine bay"
Naked Radical
Radical body... or maybe the most awesome race car bed ever...
kcpaz is offline   Reply With Quote
Old 06-26-2012, 11:28 PM   #2
kcpaz
Member#: 194611
1998 Legacy GT
Replaced the timing belt, tensioner, idlers, water pump, and a broken cam gear. Also installed a Cosworth engine oil pump.
Next came the Cosworth dry sump kit...
Then came engine/transaxle mounts in the chassis. Everything will still fit under the unmodified body work.
Next will be to add the structure back to the chassis in the form of removable braces and x-bracing that will clear the new engine configuration, then headers/exhaust.
Old 06-27-2012, 02:52 AM   #3
scubynoob
Member#: 276157
2006 WRX sedan
Will it still be turbocharged?
scubynoob is offline   Reply With Quote
Old 06-27-2012, 08:46 AM   #4
CatfaceType-R
Member#: 81102
subscribed
CatfaceType-R is offline   Reply With Quote
Old 06-27-2012, 12:37 PM   #5
kcpaz
Member#: 194611
1998 Legacy GT
Yes, using the VF36
Old 06-27-2012, 02:24 PM   #6
turboterror99
Member#: 270910
2006 WRX Tr
Cool project build. I'm in for more progress pics!
turboterror99 is offline   Reply With Quote
Old 06-27-2012, 02:34 PM   #7
RallyColtTurbo
Member#: 16819
Looks good so far. The cars gonna have a different feel for sure.
Edit: can't read.
RallyColtTurbo is offline   Reply With Quote
Old 06-27-2012, 03:07 PM   #8
wtyree
Member#: 29879
2002 WRX Wagon
Subscribed.
wtyree is offline   Reply With Quote
Old 06-27-2012, 03:11 PM   #9
Kennan04
Member#: 268525
1993 Chevy Cavalier
Red w/ Yellow flames
that is nasty, howd you mate the porsche tranny?
Kennan04 is offline   Reply With Quote
Old 06-27-2012, 05:13 PM   #10
kcpaz
Member#: 194611
1998 Legacy GT
We make an adapter kit.
Old 06-27-2012, 09:30 PM   #11
scubynoob
Member#: 276157
2006 WRX sedan
Gonna be a quick one. Any videos of when it was 'busa powered?
Old 06-28-2012, 12:55 AM   #12
RonW
Member#: 103663
1968 Porsche 912
STi v8 Spec-C conversion
looking great! can't wait to see more
RonW is offline   Reply With Quote
Old 06-28-2012, 11:17 AM   #13
amroof
Member#: 211224
2005 Saabaru
Who knows
kent you are nutz! this thing is gonna be sick! awesome work so far
amroof is offline   Reply With Quote
Old 07-01-2012, 09:02 AM   #14
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
what is the weight difference between the busa drive train and the 207/g86
Old 07-08-2012, 10:23 PM   #15
sburck
Member#: 191491
2011 Forester
+1
sburck is offline   Reply With Quote
Old 07-08-2012, 10:52 PM   #16
kcpaz
Member#: 194611
1998 Legacy GT
Not sure. Never bothered to weigh the engine after we pulled it out, and to be honest, it doesn't really matter that much. I'm guessing maybe 100lbs but I won't know until everything is done and we can get a final weight on the entire car.
Old 07-09-2012, 12:42 AM   #17
fan boy
Member#: 241243
you're getting there! keep going---
also very intriguing rear suspension---does the solid strut add travel to the shock? is it to adjust spring tension? could you explain a little?
fan boy is offline   Reply With Quote
Old 07-09-2012, 01:01 AM   #18
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
Great swap,
Check out the carberry SD rom for the 16bit ECU, it runs my spec-C motor amazingly well and gives you standalone ECU features without the cost.
lukeskywrx is offline   Reply With Quote
Old 07-09-2012, 01:29 AM   #19
kcpaz
Member#: 194611
1998 Legacy GT
There's a funky rear sway bar design integrated into the rocker arms that isn't shown in the pictures, but I think the main function of the rear suspension design is to make the spring rate progressive because of how much aerodynamic downforce the car makes.
Old 07-24-2012, 03:38 AM   #20
kcpaz
Member#: 194611
1998 Legacy GT
Some updates...
Old 07-24-2012, 09:54 PM   #21
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Very nice fab work! Should be a fine ride, now to make it street legal...
RSti_Spyder is offline   Reply With Quote
Old 07-24-2012, 09:57 PM   #22
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Yea sweet work as usual, keep it up!
Ben
Old 07-25-2012, 04:31 PM   #23
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Droool... sweet
sense of nature is offline   Reply With Quote
Old 07-25-2012, 05:30 PM   #24
BlueSTI4Me
Member#: 34361
04.7 STI
Nice, very nice.
BlueSTI4Me is online now   Reply With Quote
Old 08-15-2012, 12:13 AM   #25
kcpaz
Member#: 194611
1998 Legacy GT
Intercooler and exhaust done. Just need to make a head shield around the exhaust exit (and cut the fiberglass back a little more) and make a mount for the exhaust off of the engine/ transaxle.
FS : Ontario: DBW throttl body spacer for DBC manifold (or Spec C) cribbie Engine/Power/Exhaust 11 07-01-2016 10:27 AM
FS : N. VA Feeler New IHI VF36 (twinscroll ball bearing JDM STI Spec C) soobaviator Engine/Power/Exhaust 1 12-05-2011 11:59 PM
How to install rally roof scoop (not spec c) Gabriel~ Interior & Exterior Modification 4 09-08-2008 03:07 AM
What song is this? (version 8.8) Spheris Off-Topic 5 11-12-2005 01:55 AM
Subaru interested in radical new engine design? George71 Off-Topic 18 01-06-2005 12:27 PM
