Old 06-27-2012, 12:23 AM   #1
Zach Bitzer
Member#: 243654
2003 e55 AMG
shuffle board black
Default Tuning WGDC: EWG, 3 PORT EBCS, TD04
Current Modifications: Walbro 255 fuel pump, TD04, Tial 44mm wastegate with a 6 psi spring, grimmspeed up-pipe, invidia catless downpipe, magnaflow catback, and a grimmspeed 3 port ebcs.
Any advice what to set my WGDC Max, and Int.? Turbo Dynamics Bust and Continuous? Target boost is 19.6 psi, and I only hit it in 5th, 18 in 4th, 15 in 2nd and 3rd, and 12-13 in 1st.
Looking for more boost in the lower gears.
Using the new version of ROMRDR and ECU Flash.
Thanks!
Zach Bitzer is offline   Reply With Quote
Old 06-27-2012, 08:56 PM   #2
quazimoto
Member#: 70395
Not going to happen.
quazimoto is offline   Reply With Quote
Old 06-27-2012, 09:40 PM   #3
Zach Bitzer
Member#: 243654
2003 e55 AMG
shuffle board black
Care to share why Mr. Secretive?
Old 06-28-2012, 09:12 AM   #4
quazimoto
Member#: 70395
Because the stock ECU doesn't have wastegate compensation per gear. Even if it did you would still be hard pressed to hit 19.5 psi in first gear.
Old 06-28-2012, 09:31 AM   #5
Zach Bitzer
Member#: 243654
2003 e55 AMG
shuffle board black
I understand that. I'm not looking for target in first. Sorry if I misled.
My boost just keeps tapering bad, which I'd guess is from trying to hit triple what my wastegate springs at. Even though tials diagram says it's a 1 bar spring.
Old 06-28-2012, 11:54 AM   #6
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Host your ROM on Google documents and link it to me via PM.
Black94Snake is offline   Reply With Quote
Old 06-28-2012, 12:52 PM   #7
quazimoto
Member#: 70395
Post a datalog
Old 06-29-2012, 05:38 PM   #8
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
TD04 boost tapering at high RPM is not a wastegate or boost control issue, it's an issue with the turbo reaching it's maximum flow.
Concillian is offline   Reply With Quote
Old 07-05-2012, 11:58 PM   #9
Zach Bitzer
Member#: 243654
2003 e55 AMG
shuffle board black
Update:
I now have a 1 bar spring setup (I make 14-15 psi) on wastegate pressure.
Currently have the stock WGDC and burst and continuous on there. WGDC on idle is 25 for whatever reason.
I'm hitting target boost in 3-5, but it runs extremely rich, and there's lots of flutter.
I'd guess turn the wgdc down? But what about the burst/continuous? What sections of the max wgdc should I change?
Also, my turbo is doing exactly what it's being told to at 3-5. Hits 19 and drops slowly to 17.
Old 07-07-2012, 04:03 PM   #10
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
Actually hitting target boost in the lower gears is possible without overboosting in 4th and 5th. I have a grimmspeed 3 port and a hallman pro rx mbc in a hybrid configuration. 21psi in ALL gears
alexmartynyuk is offline   Reply With Quote
Old 07-25-2012, 10:14 AM   #11
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
Running rich doesnt have anything to do with your WGDC, play with your OL targets. At idle you dont need a lot of WGDC as you arent making any boost. From 50% throttle I have mine set to ~90% from ~1500-3 or 3500 RPM. What you can do is lower the table say 10% and see if your still hitting target boost. If not raise a couple of PSI at a time and re-check. For the flutter you most likely need to lower the WGDC in that RPM range.
edit: Got home from school. The last 2 columns (87.5 and 100% throttle) I have set to 80% wgdc from 2000-4000 rpm's, then 67 down to 57.
romanlynch is offline   Reply With Quote
Old 08-02-2012, 12:56 AM   #12
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
I had 24 peak to 21 psi at red line, now I'm not saying it made the best or optimum power at that boost level BUT it did do it.
For me the 'choice' was 22 to 18 psi...
TD04's are underrated for a fun DD
Kastley85891 is offline   Reply With Quote
Access Port and 3 port EBCS explosivo AccessPort 1 08-30-2011 03:40 PM
FS-(VA): ProDrive 3 Port EBCS Clark_Kent MAIC Private Classifieds 8 05-25-2008 08:51 PM
FS-(VA): ProDrive 3 Port EBCS Clark_Kent Engine/Power/Exhaust 4 05-25-2008 08:51 PM
Prodrive 3 port EBCS Infamous1 SCIC Private Classifieds 1 12-11-2007 11:32 AM
Prodrive 3 port EBCS plumbing JDM-STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 08-21-2007 03:51 PM
