Old 06-27-2012, 02:36 AM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Questions regarding oem ecu+MBC (EJ20G)
Aight. Prob. selling my car and might run a setup like this. Can I run the following parts?
1995 WRX EJ20G w/ TD05
Z4 ECU
walbro
02 coilpack conversion w/ bkr73 @ .028
3" catless turboback
MBC @ 1 bar PSI.
TMIC or FMIC.
#1.) Is it ok if the oem boost control solenoid isn't plugged in?
#2.) Will there be any stuttering issues? I.e. full boost until 4500, a lull, then continue to redline?
CN: Basically will the above run well?
Thanks!
JDMFLCL is offline   Reply With Quote
Old 06-27-2012, 04:42 AM   #2
pmugabi
Member#: 280926
The OEM solenoid should be plugged in electrically to avoid a CEL. The air hoses don't need to be plugged in.
The setup will work. However the octane of your fuel will determine whether or not the engine detonates itself to death.
pmugabi is offline   Reply With Quote
Old 06-27-2012, 08:56 AM   #3
JDMFLCL
Member#: 180513
Baby Baby C'mon!
91 octane. I ran it on a stock tune (no mods on motor) for a year with no problems.
Old 06-27-2012, 10:06 AM   #4
suberdave
Member#: 101865
88 GL-10 STi
i ran that same basic setup on my EJ20G for like 3-4 years. with a huge FMIC, put down 250 AWHP.
we have 92 oct fuel here.
i would suggest getting a knock light.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 06-27-2012, 11:40 AM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
Needs 93 octane and the factory bcs needs to be plugged in. It'll work fine.
Old 06-27-2012, 01:26 PM   #6
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Originally Posted by suberdave View Post
i ran that same basic setup on my EJ20G for like 3-4 years. with a huge FMIC, put down 293 AWHP.
-=Suberdave=-
wait wait wait...same "basic" setup? Wasn't this your mod list for your 293 dyno pull?
1996 EJ20G Full standalone ViPEC ECU 780cc injectors FMIC Stock TDO5h 16g Blitz boost controler @ 17PSI 05 Ign coil mod APS BOV vented Full 3" TBE lots of tuneing...
That's taking quite the liberty with approximation Dave
rob is offline   Reply With Quote
Old 06-27-2012, 01:27 PM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Yep, but you do need to cap off the return line at the intake pipe. You can't let that one dangle.
-Rob
Old 06-27-2012, 02:24 PM   #8
JDMFLCL
Member#: 180513
Baby Baby C'mon!
We only have 91 octane here
Old 06-27-2012, 03:43 PM   #9
suberdave
Member#: 101865
88 GL-10 STi
you are right. before the injectors and the standalone. it was not 293.
it was 250 hp 230 tq. with the Z4 ECU and a turboXS MBC.
to get it to 293 i did have to give it more fuel. and some more tuneing.
but i did run it with the stock ECU for a few years before the standalone.
-=Suberdave=-
P.S. i fixed my other post...
Old 06-27-2012, 11:14 PM   #10
JDMFLCL
Member#: 180513
Baby Baby C'mon!
So I take it I can't run the above setup on 91 octane?
Old 06-27-2012, 11:26 PM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
You can but it's kinda risky. It would be safer with one of the lower performance ECUs and less boost on 91.
Old 06-28-2012, 12:28 AM   #12
eg33GC
Member#: 206851
56 Belair
Pro Street
As a seller I'd be worried about liability.
Rob and I have a ton of stock roms, of which I'd recommend like a u8 or a v9 wrx, which could be burned for you.
I'd lower the boost to wastegate and wave goodbye
eg33GC is offline   Reply With Quote
Old 06-28-2012, 03:25 AM   #13
JDMFLCL
Member#: 180513
Baby Baby C'mon!
pm me
Old 06-29-2012, 06:31 AM   #14
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Well update. I did alot of reading around the forums, so I'd like to rephrase my question.
Can I run a FMIC w/ VTA bov+turboback on a Z4 ECU @ the stock 12.7psi? No MBC (stock boost solenoid). I.e. will it run smoothly?
Old 06-29-2012, 06:32 AM   #15
JDMFLCL
Member#: 180513
Baby Baby C'mon!
double post
Old 06-29-2012, 09:16 PM   #16
69subaru360
Member#: 159682
1995 WRX
2015 F150
The boost might be erratic with the FMIC. It will have more boost loss through the core and the ecu might go wacky trying to compensate. Add a cheap mbc and it'd be fine.
Old 06-30-2012, 02:09 AM   #17
JDMFLCL
Member#: 180513
Baby Baby C'mon!
so MBC @ 12.7 psi w/oem solenoid plugged in and I'd be fine?
Old 06-30-2012, 01:13 PM   #18
69subaru360
Member#: 159682
1995 WRX
2015 F150
yes45
question regarding stock ECU problemcat13 Engine Management & Tuning 8 12-24-2006 05:25 AM
Silly n00b question regarding OEM speakers and the 'upgraded speaker kit' Xymox Car Audio, Video & Security 1 08-29-2005 04:27 PM
n00baru question regarding OEM speakers and the 'upgraded speaker kit' Xymox Newbies & FAQs 1 08-29-2005 04:17 PM
Question regarding OEM radiators a1ex General Community 12 04-28-2005 05:05 PM
Questions in regards to ECU resetting. Desolate One Newbies & FAQs 2 02-20-2003 03:59 PM
