Old 06-27-2012, 04:40 PM   #1
nappynick
Member#: 317114
'12 WRX Hatch
Default New AP
Just got my AP for my '12 WRX. Is there any precautions i need to do or anything at all to be aware about? Im just going stage 1 91ACN with stock intake. thanks in advance...
nappynick is offline   Reply With Quote
Old 06-27-2012, 10:05 PM   #2
hutch959
Member#: 267463
my advise is to start with the most conservative map, log, and then go up as you see the data.
i would start witht the 91 ACN LWG map. then if no knock, and under boosting, go to the 91 ACN map.. ..
repeat.
this way you find what your fuel and your cars knock and boost characteristics are.
hutch959 is offline   Reply With Quote
Old 06-28-2012, 09:30 AM   #3
Cobb Tuning
Member#: 4803
You are good to go if you have the stock intake. As hutch959 mentioned, it is a good idea to get some data logs. Check out our data logging video:
Bill
Old 06-29-2012, 05:02 PM   #4
nappynick
Member#: 317114
'12 WRX Hatch
Got a datalog today. just want t know if everything looks right. thanks
https://docs.google.com/open?id=0B_h...l9NR0p3ZVpuaHM
Old 06-30-2012, 10:24 AM   #5
Cobb Tuning
Member#: 4803
Can you turn on the preview function?
Thanks,
Bill
Old 06-30-2012, 12:13 PM   #6
nappynick
Member#: 317114
'12 WRX Hatch
I can't figure it out. it doesn't show me an option any where about setting a preview.
Thanks,
Bill
Old 06-30-2012, 12:21 PM   #7
nappynick
Member#: 317114
'12 WRX Hatch
Old 06-30-2012, 03:35 PM   #8
Cobb Tuning
Member#: 4803
Log looks good, but you are underboosting some. You can download the high wastegate (HWG) version of your map from the maps section at cobbtuning.com if you like. Use the AccessPORT Manager to transfer the map to your AccessPORT and then reflash to the car (Tune -> Change Map).
Bill
Old 06-30-2012, 04:05 PM   #9
nappynick
Member#: 317114
'12 WRX Hatch
ok...thanks. i will give it a try. and see what comes of it. It should be ok to do correct? what is the difference between ACN91, ACN91 LWG and ACN91.
Old 06-30-2012, 08:09 PM   #10
nappynick
Member#: 317114
'12 WRX Hatch
Here is a new Data Log using ACN 91 HWG. Hopefully everything looks good. Thanks again...
Old 07-01-2012, 01:59 AM   #11
nappynick
Member#: 317114
'12 WRX Hatch
Old 07-01-2012, 10:27 AM   #12
Cobb Tuning
Member#: 4803
Boost is good now. You are good to go!
Bill
Old 07-01-2012, 02:52 PM   #13
nappynick
Member#: 317114
'12 WRX Hatch
Thanks again..
Old 07-01-2012, 03:35 PM   #14
11SubieWRX4D
Member#: 264443
2011 WRX Sedan Stg 2
I recently bought a Cobb AP too. Can I use this thread to post my log and recommend me me which map i need to use? Thanks.
11SubieWRX4D is offline   Reply With Quote
Old 07-01-2012, 05:27 PM   #15
11SubieWRX4D
Member#: 264443
Hi Bill, can you check my data log?
http://forums.nasioc.com/forums/show...1#post37502755
Old 07-01-2012, 11:31 PM   #16
Cobb Tuning
Member#: 4803
Posted a response in your thread.
Bill
Old 07-03-2012, 10:30 PM   #17
STISTUNNA
Member#: 310765
2012 STI
not trying to thread jack but I just installed stage 1 91 v310 boost select on my 12 sti sedan ive got the Cobb intake, Invidia q300 exhaust and the cobb. I wanted to post my log but I have no clue how to post up the log file i did see some knock and now im a bit worried. I am new to the game and have no clue as to what i am looking at....any help would be much appreciated.. here are the three rows of data where i saw the knock...
Time A/F Learning 1 (%) Boost (PSI) Calculated Load (g/rev) Dyn. Adv. Mult (DAM) Dynamic Adv. () Feedback Knock () Fine Knock Learn () Ignition Timing () MAF Volt. (V) MAF (g/s) RPM (RPM) TD Boost Error (PSI) Throttle Pos. (%) Wastegate Duty (%)
62.24 0 11.81 2.18 1 2.81 0 -1.4 20.5 3.92 224.67 6207 0 100 34.51
69.88 0 9.83 2.05 1 3.1 -1.4 0 16.5 3.66 172.33 4489 5.59 100 57.65
70.22 0 17.29 2.74 1 4.22 -1.4 0 14 3.84 208.1 4497 -1.59 100 46.67
STISTUNNA is offline   Reply With Quote
Old 07-03-2012, 10:32 PM   #18
STISTUNNA
Member#: 310765
2012 STI
well that was a failed attempt... i tried again but no luck
Old 07-05-2012, 10:13 AM   #19
Cobb Tuning
Member#: 4803
Best way to post your log for Nasioc is to put it up on google docs (make sure the permissions are set to public) and then link to it here. Alternatively, you can attach the .csv file to a post at the cobb forums:
https://forums.cobbtuning.com/forums/forum.php
Bill
Old 07-05-2012, 10:48 PM   #20
STISTUNNA
Member#: 310765
2012 STI
thanks bill let me try on cobb.
FS: UT 04 STi Airbox, TBE, New AP V2, new FMIC, Short Ram XSTIc Engine/Power/Exhaust 10 01-28-2009 11:22 PM
FS: 04 STi Airbox, TBE, New AP V2, new FMIC, Short Ram XSTIc RMIC Private Classifieds 3 12-03-2008 10:49 AM
so is that the new AP on Cobbs new site? i never saw the old one.... STI_SLC AccessPort 4 11-01-2006 12:49 AM
new AP CA maps Bishop Engine Management & Tuning 35 09-06-2004 11:49 PM
new AP antitheft maps citra Engine Management & Tuning 1 08-13-2004 08:16 PM
