Old 06-27-2012, 05:47 PM   #1
crazy_flip
Member#: 290253
2007 Sti atp gtx3076
Pearl white
Default ATP gtx3582
Hi was looking for dynos sheets of the stock location ATP gtx3582 was wondering if anybody here has this turbo on their cars or has any dyno graphs. I'm looking to get this turbo
crazy_flip is offline   Reply With Quote
Old 06-27-2012, 06:06 PM   #2
modusvivendi
Member#: 214073
2008 Impreza WRX STi
Bsatin white pearl
use the search button in proven power bragging
modusvivendi is offline   Reply With Quote
Old 06-27-2012, 07:05 PM   #3
crazy_flip
Member#: 290253
Pearl white
I did couldn't find anything about the apt gtx3582
Old 06-28-2012, 09:22 AM   #4
littlewhitewagon
Member#: 103068
11 STI sedan
Is your engine built or do you have meth / high octane gas? If not, you won't get close to what that turbo can do. Consider headwork for high rpm flow improvement too. I have the ATP gtx3076r 3" stock location and it's barely waking up but I need pistons and more octane. Search my posts.
littlewhitewagon is offline   Reply With Quote
Old 06-29-2012, 01:48 AM   #5
crazy_flip
Member#: 290253
Pearl white
Ok thanks I just got forged pistons with supporting mods no head work
Old 06-29-2012, 12:42 PM   #6
Clark Turner
Member#: 178047
02 WRX STI Spec C
Slow to spool.
Clark Turner is offline   Reply With Quote
Old 06-29-2012, 05:24 PM   #7
littlewhitewagon
Member#: 103068
11 STI sedan
Agree with Clark.
Any particular reason to not go rotated? Want to keep it stock looking with bolt on parts?
Old 06-29-2012, 05:28 PM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Stock location 35r is just an exercise in futility...
Old 06-29-2012, 09:31 PM   #9
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Originally Posted by Clark Turner
Slow to spool.
This.... I had one
It was fun though, I should have gone rotated.
2gnt2wrx is offline   Reply With Quote
Old 07-04-2012, 03:51 PM   #10
crazy_flip
Member#: 290253
Pearl white
i live in california and the cops here are no bueno with rotated kits i was looking at the stock location atp gtx3576 they say it 3076 spool but with 35r top end anybody have inputs on that?
Old 07-04-2012, 04:16 PM   #11
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
Who's they? I have the non gtx version of the 3586 and spoolup was at 4700rpm and topend was less than a rotated 35r.
More like 40r spoolup and 3076 topend.
Old 07-04-2012, 04:47 PM   #12
crazy_flip
Member#: 290253
Pearl white
what do you mean 3586? i spoke with atp the gtx3576 has the smaller compresser wheel which is the 76mm compared to the 82mm which is on the gtx3582 which is why i would assume the spool up on the gtx3576 would be faster than the 3582.. in my opinion with the gtx3076 the 76mm wheel is to much for the 30 housing. so its kind of a mixmatch
Old 07-04-2012, 05:13 PM   #13
fourmicah
Member#: 128760
2015 STI
If they are making a GTX3576, that would be an awesome combo, although I doubt anything ATP put out would spool quickly. Their turbos have always seemed to spool slow.
fourmicah is offline   Reply With Quote
Old 07-04-2012, 08:39 PM   #14
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
I meant 3582 damn little keyboard.
Old 07-04-2012, 10:41 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The 3576 has been proven to spool similarly to the 3076 but with higher power capability. Search around some guys and you'll find the details. Basically, since the GTX3576-R has been introduced, there's not much point to the 3076.
KillerBMotorsport is offline   Reply With Quote
Old 07-04-2012, 10:59 PM   #16
crazy_flip
Member#: 290253
Pearl white
Yah that's what I wanted to hear I can't wait to get the turbo the ATP gtx3576
Old 07-05-2012, 01:38 AM   #17
LBell05STI
Member#: 305890
2005 STI
One thing you must understand is that atp is using the OEM uppipe to feed it air. It is about half the size of any rotated setup so it's near impossible to get good spool. It's not atps fault.
LBell05STI is offline   Reply With Quote
Old 07-05-2012, 08:49 AM   #18
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sorry to pick on you, but this is interweb misinformation at its best. For best spool you want an up-pipe that is OEM sized or smaller. Large tubing slows exhaust velocity, is a larger volume to pressurize, and creates a large ridge (flow disruption) as the exhaust enters the smaller turbine housing.
If we were talking N/A cars it would be a different story, but turbocharged cars play by a completely different set of rules when it comes to header/exhaust design. Smaller is almost always better unless you're building a single use car ie; 1,000whp drag car.
Old 07-09-2012, 11:16 AM   #19
littlewhitewagon
Member#: 103068
11 STI sedan
And if you want reference for what a gtx3076r does, search my posts. I have one in my car. I get 21psi before 4k and it keeps pressure to redline. Put down 37x whp on the SoCal Cobb dyno. This is with stock pistons and ca91 gas only. Pick up July 2012 import tuner for the write up, it's in the back.
Old 07-09-2012, 06:48 PM   #20
LBell05STI
Member#: 305890
2005 STI
If that were the case how are people spooling gt30/gt35rs alot sooner on rotated setups?
Old 07-09-2012, 07:14 PM   #21
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
Being rotated doesn't mean a larger up pipe. The purpose is to allow for a larger intake so that the turbo has less restriction sucking in air to build pressure, hence faster spool.
Cr4ckfi3nd is offline   Reply With Quote
Old 07-09-2012, 08:25 PM   #22
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
A lot sooner? You have same size turbo (rotated vs non-rotated), on the same car, with plots from an independant source showing this?
Old 07-10-2012, 11:27 PM   #23
Irishflame27
Member#: 325766
The GTX3576 is a really neat turbo. Packing the best of both worlds from the 30R and the 35R you cant go wrong. Very good pricing here
Last edited by Unabomber; 07-11-2012 at 06:23 AM. Reason: not sure if spammer or moron, either way, you are not welcome
Irishflame27 is offline   Reply With Quote
Old 07-11-2012, 07:24 AM   #24
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
Banned in 1 post. Lol
Old 07-11-2012, 12:55 PM   #25
littlewhitewagon
Member#: 103068
11 STI sedan
The stock location GTX3076R / GTS3576R uses a 3" inlet hose, but there is still a 90 degree turn since the stock air cleaner location mandates this. And as everyone knows, the space under the intake manifold isn't all that spacious and this is really the issue when comparing the rotated setups to stock location.
But in states like CA, stock location is the way to go... the polished housing may not be the best idea, but it's pretty...
WTB : Gtx3582 sdcoolguy_ryan Private 'Wanted' Classifieds 1 12-14-2011 09:44 PM
which is louder? gt3582 or gtx3582 spool Kovs04sti Newbies & FAQs 16 11-30-2011 12:27 PM
WTB : Wtb Garrett Gtx3582 WhiteKnight Private 'Wanted' Classifieds 1 04-08-2011 02:35 PM
