Old 07-11-2012, 08:09 PM   #26
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The flange size and bend shouldn't matter much, if at all, since the actually compressor inlet is ~2.4" (IIRC). Which is still much smaller than the roughly 5% you'd loose through the 3" 90 bend.
KillerBMotorsport is offline   Reply With Quote
Old 07-11-2012, 08:27 PM   #27
littlewhitewagon
Member#: 103068
11 STI sedan
You mean the actual diameter at the cold side blades? Yeah, for sure less than 3", you can see in the picture of mine that is attached... don't have measured numbers though... and I'm not taking that thing out to measure...
littlewhitewagon is offline   Reply With Quote
Old 07-11-2012, 09:22 PM   #28
Subarusesh
Member#: 288160
2008 Impreza 2.5i
Originally Posted by littlewhitewagon View Post
And if you want reference for what a gtx3076r does, search my posts. I have one in my car. I get 21psi before 4k and it keeps pressure to redline. Put down 37x whp on the SoCal Cobb dyno. This is with stock pistons and ca91 gas only. Pick up July 2012 import tuner for the write up, it's in the back.
how do you get 21 psi before 4k (on that turbo) on 91 cali?
do you have a TMIC?
just curious, not doubting.
Subarusesh is offline   Reply With Quote
Old 07-12-2012, 03:53 PM   #29
561wrx
Member#: 166427
03 wrx
The stock location GTX3076R / GTS3576R uses a 3" inlet hose, but there is still a 90 degree turn since the stock air cleaner location mandates this. And as everyone knows, the space under the intake manifold isn't all that spacious and this is really the issue when comparing the rotated setups to stock location.
But in states like CA, stock location is the way to go... the polished housing may not be the best idea, but it's pretty...
Did the hose come with it or did pay extra for it?
561wrx is offline   Reply With Quote
Old 07-12-2012, 04:58 PM   #30
littlewhitewagon
Member#: 103068
11 STI sedan
do you have a TMIC?
I have a Perrin FMIC. In the lower gears, 1st especially, it won't happen. But if you are cruising in a higher gear, the load will be there and it gets to target boost decently quickly. On the dyno, it gets there around 4200 or so. I think it has to do with having headers and an uppipe with the right tune. But even then, when you compare it to how the VF48 felt... it's a bit of time to wait.
The new angle hose is included for those who want to run the FMIC. We used it when we dyno'd it before the FMIC for fun. The FMIC with retune was worth 35hp and 31tq. The gains are seen as soon as the boost is up.
Old 02-03-2013, 01:51 PM   #31
Rexypoo
Member#: 286745
2004 WRX STI
JBP
Not trying to bring up old stuff. But just bought the GTX3576 externally gated stock location turbo for my 04 STI. Was looking at the AMR pro series up pipe (2.5"), and began to wonder what the size was for the inlet? I have dug around and found nothing. Any takers on this?
Rexypoo is offline   Reply With Quote
Old 01-15-2014, 06:57 PM   #32
Rexypoo
Member#: 286745
2004 WRX STI
JBP
BUMP... Mine is in the shop right now getting a couple other things done. Same GTX3576 externally gated stock location turbo and ready to get the damn thing done. Hearing bad things about the turbo though. Anybody have any new info on the subject?
Old 01-16-2014, 09:16 PM   #33
giantbrandon
Member#: 329666
2008 Liberty sti
the blouch dom 3.5 is another option too look at, think its turbine wheel is a fraction smaller than a 3576 but its bigger than a 3076
giantbrandon is offline   Reply With Quote
Old 09-25-2014, 03:37 PM   #34
waylouderthanyou
Member#: 266168
2007 WRX STI
Satin White Pearl
atp gtx3582r come with a 0.72 a/r and flows 67lbs/min. just fyi
waylouderthanyou is offline   Reply With Quote
Old 09-25-2014, 04:25 PM   #35
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ I'm curious how you came up with that figure since the GTX3582 flow 75lbs/min.
WTB : Gtx3582 sdcoolguy_ryan Private 'Wanted' Classifieds 1 12-14-2011 09:44 PM
which is louder? gt3582 or gtx3582 spool Kovs04sti Newbies & FAQs 16 11-30-2011 12:27 PM
WTB : Wtb Garrett Gtx3582 WhiteKnight Private 'Wanted' Classifieds 1 04-08-2011 02:35 PM
