Old 06-27-2012, 09:45 PM   #1
anon_az
Member#: 160782
2004 Impreza WRX STi
Default Headlight refinishing (sanding/polishing) vs. deoxidizer
I see threads with people showing off their freshly-refinished headlights and the great results they get, but I've recently come across a couple of sites (admittedly ones trying to sell their product) stating that completely removing the UV coating on plastics headlights with sanding and polishing isn't the answer and that the lenses will haze right back up.
My question to those who have refinished with abrasives is : how long did the lenses stay that way? Do people see lenses haze right back up? Is the story that the liquid lens restorer companies are trying to sell BS or does rubbing away the UV coating really do damage? I've seen Pittman ALR (Acrylic Lens Restorer) get some good reviews, saying the haze goes right away with no elbow grease. Those liquid restorers aren't cheap but I'll go that route if they definitely fix the problem.
I'm looking to refinish my STi's headlights which are somewhat hazed and want to be sure I'm doing the right thing.
anon_az is offline   Reply With Quote
Old 06-27-2012, 11:22 PM   #2
minorc
Member#: 208229
2010 STi
Depending on how bad they are I use 1500-2000 grit wetsand paper, uf4000 menzerna polish with my flex then seal with collinite 845 and reload 12 hrs later.
Lasts a few months then I reapply wax and or sealer.
They don't turn yellow a week after or anything don't worry
minorc is offline   Reply With Quote
Old 06-28-2012, 08:40 PM   #3
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
If your headlights are already oxidizing and show signs of yellowing, chances are the UV coating from the factory is long far gone.
pho_shizzle is offline   Reply With Quote
Old 06-28-2012, 10:08 PM   #4
DerrickRH
Member#: 75078
2000 Legacy GT
Black Granite Pearl
this is fact
DerrickRH is offline   Reply With Quote
Old 06-28-2012, 11:04 PM   #5
wantsti
Member#: 134764
04 sti
java black pearl
Sand them and put a shield on them like venture shield. 4 years and clear as new
wantsti is offline   Reply With Quote
Old 06-29-2012, 12:49 AM   #6
Jarvisss
Member#: 301117
2016 WRX
Use the 3M headlight restorer kit. It's the only kit that works and lasts. I've used it on many cars including my 05 STi with great results and it's under $30 at most auto parts stores.
It takes a little while and you might go through a few batteries if you're using a cordless drill. The key is to take your time and watch out not to stay in one spot too long. If you have an 04 or 05, the little bump can be tricky, but you just need to keep moving and avoid using the edge of the sandpaper. It can also be messy so do it outside, find a chair, put a crappy towel over your lap, and set the headlight on your lap. Keep a spray bottle with water and some paper towel handy, and a few beers
Don't try to do it while it's still on the car, it's really uncomfortable and you'll wind up rushing the job and making a mess. You'll have to take the front bumper cover off unfortunately to get the headlights out
Jarvisss is offline   Reply With Quote
Old 07-02-2012, 12:42 PM   #7
anon_az
Member#: 160782
Cool, thanks for the feedback. I'll look into venture shield and the 3M kit
Old 07-04-2012, 07:32 PM   #8
joewrx628
Member#: 296411
2011 4dr STi
Iv take my lights out many times without removing the bumper. All you need to do is take the grill off and pull it a little bit and you can get the light out.
joewrx628 is offline   Reply With Quote
Old 07-04-2012, 08:29 PM   #9
Fredward
Member#: 322518
2008 2.5i Hatchback
1995 Mercedes-Benz S600
I also used the 3M kit when I had my Nissan Maxima before getting new headlights. Just remember that after you finish the process, use 3M's polish or something similar to keep that new finish.
Fredward is offline   Reply With Quote
Old 07-04-2012, 08:31 PM   #10
emazz104
Member#: 281811
04 WRX
World Rally Blue
There are lots of cleaners that work, but they just shine the headlights.
The 3M works great because you're actually sanding a layer off the headlight, and polishing it, just like buffing a car, it will take out the scratches.
emazz104 is offline   Reply With Quote
Old 07-04-2012, 08:44 PM   #11
Down_Shift
Member#: 115457
66 Grown up subaru
AW on red
Just used Meguire's and 3M.
The Meguire's is way easier to use.. And it's all wet sand than plastx.
3M has 2 sand pads.. then a wet sand.. followed by a rubbing compound.
Remember to seal them with sealant or good wax to keep the finish..
Even with sealing regularly, I have to buff it every year.
Down_Shift is offline   Reply With Quote
Old 07-07-2012, 06:49 PM   #12
ZIP23
Member#: 67003
2015 WRX
What sealant is good I want to do this but don't have a clue
ZIP23 is offline   Reply With Quote
Old 07-07-2012, 11:03 PM   #13
aznburn210
Member#: 84062
2005 WRX
CGM on Bronze Work's
I just did this with the Meguires Kit today. on 4 cars. The pro-kit I found has the headlight sealant.
aznburn210 is offline   Reply With Quote
Old 07-10-2012, 08:34 AM   #14
Shake-n-Bake
Member#: 324646
2007 WRX Wagon
I used some Meguire's headlight restore with my Porter Cable buffer - took the haze right off. Then I applied a coating of wax.
Shake-n-Bake is offline   Reply With Quote
Old 07-10-2012, 08:42 AM   #15
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
i used this kit this past weekend and i am very impressed with the results. very easy to do also. i also put some sealer on the headlights.
Daddy_Digital is offline   Reply With Quote
Headlight Refinishing? proletariandan Mid West Subaru Owners Club Forum -- MWSOC 11 03-10-2009 02:04 PM
Did some headlight refinishing! Clayton Member's Car Gallery 15 11-03-2007 10:22 PM
Headlight refinishing! Clayton South West Impreza Club Forum -- SWIC 10 10-30-2007 02:31 AM
headlight refinishing dubya-R-ex Interior & Exterior Modification 8 07-12-2007 09:22 AM
Headlight weight question? HID Vs. Non HID doggyollie Electrical & Lighting 6 05-20-2006 11:36 AM
