Old 06-27-2012, 10:05 PM   #1
06WRXLTD
Member#: 295201
2006 WRX Limited
World Rally Blue
Wanted some opinions on these datalogs. Let me know if you can't view them.
One is a 3rd gear pull, other is 3rd and 4th.
Car is an 06 WRX, Megan Racing catless DP, Cobb AP v2, Stage 2 91 MTv300
EDIT: I'm running stock cat back with the reducer between the DP and cat back.
https://docs.google.com/open?id=0B6U...UxaZThIUXNRUlk
https://docs.google.com/open?id=0B6U...FVoVkFIblR3WFU
Just let me know if anything looks suspicious. I can't pinpoint what it is but overall the car doesn't seem to be running tip top.
06WRXLTD is offline   Reply With Quote
Old 06-28-2012, 09:40 AM   #2
Cobb Tuning
Member#: 4803
The dynamic advance multiplier (DAM), which starts at 0.6 in this map after you install the AccessPORT, reflash a map, or reset the ECU, has not learned up to the normal 1.0 max, which takes some driving (and specifically seeing moderate steady boost in the 2000-3000 RPM range makes it more likely to learn). That may be why it feels a little soft. Give it some time and then check the DAM and get a data log when it has learned up to 1.0.
Bill
Old 06-28-2012, 10:05 AM   #3
06WRXLTD
Member#: 295201
2006 WRX Limited
World Rally Blue
I was wondering if that would have an effect. I was running economy then flashed to stage 2 and soon after did the data log. I brake boosted a decent amount of time between 2-3k before the logs but I guess it didn't help enough. I'll post up some more once it's learned.
Thanks!
Old 06-28-2012, 06:10 PM   #4
06WRXLTD
Member#: 295201
2006 WRX Limited
World Rally Blue
Both are 3rd gear pulls. One of the files was throwing fits, let me know if you can't open it.
https://docs.google.com/open?id=0B6U...0xhUjJUVENCXzg
https://docs.google.com/open?id=0B6U...UdxQzk0S3B5cFE
Old 06-29-2012, 07:34 AM   #5
Cobb Tuning
Member#: 4803
Logs look good. The only issue is that you are underboosting some. You can play with shortening the wastegate arm (various DIY threads on Nasioc about this), but it is not too bad.
Bill
Old 06-29-2012, 09:32 AM   #6
06WRXLTD
Member#: 295201
2006 WRX Limited
World Rally Blue
Bill
Thanks a ton! I'm glad to hear I'm running safe.
If you don't mind I'll adjust it and reflash, then post up a couple more logs once it's learned just to make sure I'm 100% safe.
Thanks again.
Old 06-30-2012, 10:39 AM   #7
Cobb Tuning
Member#: 4803
Thanks again.
No problem. Feel free to post as many logs as you like. We try to look at as many of the logs of those customers running our OTS map as possible.
Bill
