06-28-2012, 09:41 AM | #1 |
Member#: 193222
Vehicle:05 Wrx 1.5xtr 6spd 2.5 hybrid 367whp/363wtq |
new personal 1/4 mile best vf34 hybrid
i went out to the local track last night "Cecil County Dragstrip" and got in a few runs (4 to be exact) but I'm only posting up my first run lol since the others, while not bad, aren't worth posting.
Event: quarter mile Location: cecil county drag strip cecil county, md Ambient Temp: 85 degrees Fahrenheit Elevation: at sea level Weather: 85 degrees and clear (night time) Track and Conditions: asphalt/concrete Tires: Nitto Neo Gen 225-45-17 Car: 2005 wrx Tuner: jorge @ iag Dyno Info: dyno jet Transmission: 5spd stock gearset Gear: 4th Peak HP at RPM: 304whp Peak Torque at RPM:334wtq Baseline hp/tq for a stock on same dyno: n/a Target Boost: 17psi Target AFR: 11.2 Fuel: 93oct Engine/Power Modifications:Brand new Sti short block, Wiseco pistons (99.5mm), stock 2.0 heads, vf34 turbo, 565cc injectors, walbro 255 fp, Perrin turbo inlet, Turbo XS fmic, invidia bellmouth dp-catless, invidia n1 street catback, gt-spec EL header, killer-B utlimate oil pickup, sti oil pan, sti dip sti, sti baffle, IAG 38mm ewg, TurboXS shorty intake, grimmspeed ebcs, IAG tgv deletes, tuned on 17psi Modifications: stock trans with NEW stock clutch/flywheel Suspension Modifications: BC coilovers, cobb front sway, kartboy front and rear endlinks, whiteline front shifter stay bushings, whiteline rear diff lock down kit, kartboy front and rear shifter bushings, torque solutions motor mounts, torque solutions pitch stop mount, groupe n trans mount, kartboy short shifter, spt short shifter linkage Other Modifications: spare tire removed car 137 my best time previous was 12.475 @ 109.49 but that was at 50 degrees and before when my car was runninh 21psi. now that's retuned with an ebcs and the tgv deletes, it's running only 17psi and it ran an almost identical time ( a lil faster ) and it was 35degrees hotter lol. so i'd saythe tune did pretty good
06-28-2012, 12:29 PM | #2 |
Member#: 275888
Vehicle:2011 WRX Limited SWP |
That track is ridiculously fast. I ran my Eclipse there back in the day and picked 3/10ths and 3MPH over 75-80 near me. Any plans to retune at 21PSI again?
06-28-2012, 01:23 PM | #3 |
Member#: 193222
They just repaved the track this past off season. It's now concrete til the 1/8th. And I need more injector and a better clutch for 21psi
06-28-2012, 09:03 PM | #4 |
Member#: 147972
Vehicle:2004 wrx hybrid 18g 11.9@117 dd |
The first run is always the fastest!
06-30-2012, 08:19 PM | #5 |
Member#: 322417
SCIC
Vehicle:05 WRX STI Obsidian Black Pearl |
Nice time! 12.5 @110 is pretty fast!
06-30-2012, 08:47 PM | #6 |
Member#: 323578
nice time!
06-30-2012, 08:47 PM | #7 |
Member#: 323578
07-01-2012, 07:09 AM | #8 |
Member#: 142029
Vehicle:2013 Forester 2008 350z, 1991 Miata BRG |
nice run man
07-01-2012, 09:05 AM | #9 |
Member#: 193222
Thanks
07-02-2012, 01:59 PM | #10 |
Member#: 306871
nice time!
07-02-2012, 02:14 PM | #11 |
Member#: 142608
TXIC
Vehicle:2003 Sonic Yellow Marginally well behaved. |
Nice run man...hybrids are awesome.
07-03-2012, 11:00 PM | #12 |
Member#: 193222
Thanks. The extra .5L is def nice. Esp since my hybrid is 9.5:1cr
New Z06 1/4 mile run | Jay04WRX | Off-Topic | 12 | 11-08-2005 04:35 PM |
Congrats Phil! A new fastest 1/4 mile time? | nmyeti | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 60 | 05-07-2002 11:31 AM |
New Personal Best 1/4 mile time... | Bighurt1 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 26 | 04-15-2002 08:26 PM |
New low 1/4 mile times | kastle | South West Impreza Club Forum -- SWIC | 20 | 05-30-2001 10:59 AM |
