Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-29-2012, 10:28 PM   #1
88rxn/a
Member#: 135140
Default cam seals help
Does anyone have the correct cam seal part numbers? Looking on rockauto they show different sizes and i am not sure which ones i need? Pretty sure i need 4 of them correct? mine are leaking oil pretty bad.
This is for a 1995 subaru legacy 2.2L
88rxn/a is offline   Reply With Quote
Old 07-01-2012, 01:33 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
When it comes to that sort of thing I'd be inclined to go through a dealer, just to be sure I get the right part based on my VIN.
Alternatively, you can order a couple different parts from rockauto and then return what doesn't appear to be the correct size.
Old 07-01-2012, 03:25 PM   #3
darryldowney
Member#: 323720
1996 Legacy
there is only 2 cam seals, and if you buy the cam seal kit it should come with 2 o-rings as well.
darryldowney is offline   Reply With Quote
Old 07-10-2012, 03:51 AM   #4
beaconhillkilla
Member#: 174710
1992 Legacy Turbo
Dream Machine
If your car is DOHC then you will have 4 front cam seals, if it is SOHC you will only have 2. There are no rear cam seals. I just ordered all of my seals from rockauto with no problems
beaconhillkilla is offline   Reply With Quote
Old 07-11-2012, 11:49 AM   #5
88rxn/a
Member#: 135140
I dont remember rockauto having kits for the cam seal? Ill have to look again. Thanks for the help so far though!
2.2 impreza cam seal HELP!!!! beppomarx Service & Maintenance 7 01-01-2013 07:30 PM
Need help identifying part# for Rear CAM Seals Mike1967 Normally Aspirated Powertrain 11 04-22-2007 03:16 PM
cam seal installation help for a noob q2brass Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-07-2007 06:47 PM
Help with cam seal procedure and SOA TlistGT Service & Maintenance 7 11-15-2006 07:15 PM
HELP! My head cam seal fell into the motor f1uxx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-11-2006 12:34 PM
