Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 08-30-2002, 01:22 AM   #1
RSarte
Member#: 4965
2004 WWhite Evo8 GSR
2010 Outback 2.5i Premium
Default How do u maketrunk light kit sound the alarm?
i've read that with the trunk light kit, the alarm would go off, if you try and open the trunk if the alarm is still armed. Well for some reason it doens't do it on my car. I followed the instructions to install the trunk light, but the alarm thing doesn't seem to work. Help would be great or pointing me to the right posts would be cool!
thanks in advance.
RSarte is offline   Reply With Quote
Old 08-30-2002, 08:51 PM   #2
Zypper
Member#: 5201
'02 WRX Wagon
'11 Versys 650
Allright. You probably need your relay to be hooked to the trunk light switch. Trunk light switch circuit goes on the coil side, the circuit from/to the alarm goes on the switch side. Make sure the leads from the trunk relay are inserted into the proper I/O pins on your alarm.
If everything works right, you should hear the relay go "click" when you open the trunk. Try listening for it by pressing on the trunk light switch a few times to cycle the relay.
Also make sure your alarm is programmed to recognize the trunk open relay.
Hope this helps.
Zypper is offline   Reply With Quote
How do you make the Rally Style Jack Stands? RedefinedTR Interior & Exterior Modification 21 03-03-2010 10:54 PM
how do you make the strut's shaft not turning when tightening down the strut bolt? qualityracer Brakes, Steering & Suspension 14 06-08-2009 02:53 PM
What's in your trunk / how do you setup your trunk? Ken Off-Topic 21 05-23-2004 10:16 PM
How do you make the WRX sharper without adding much harshness? dunny Brakes, Steering & Suspension 22 01-21-2004 11:43 PM
how do you make the 02 2.5RS go fast? azn_gg Newbies & FAQs 12 11-29-2001 02:50 AM
