Old 06-30-2012, 01:54 PM   #1
jorge0886
Member#: 269257
2011 STI Limited
Default Stage 2 High vs Low Wastegate?
Guys, last night I finally went Stage 2 in the 2011 STI.
SF Intake, Up Pipe, and Downpipe. Flashed to Stage 2 + SF Intake, but stayed with the Normal Wastegate.
I don't have a cat-back yet.
What is the different in the Low vs High Wastegate?
Thanks
jorge0886 is offline   Reply With Quote
Old 06-30-2012, 03:37 PM   #2
Cobb Tuning
Member#: 4803
Thanks
Low wastegate map would be used if you are overboosting. High wastegate map would be used if you are underboosting by more than 1 psi (your peak target in 4th gear for STi). Normal wastegate map is what you try first. I would go ahead and get a data log and we can see where you are at:
Bill
Old 06-30-2012, 04:16 PM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
Got that backwards, Bill ; )
Airboy is offline   Reply With Quote
Old 06-30-2012, 08:58 PM   #4
Cobb Tuning
Member#: 4803
Doh - brain fart! Fixed - thanks Sunny.
Old 07-01-2012, 06:23 AM   #5
jorge0886
Member#: 269257
2011 STI Limited
Wow!
Perfect response.
Thanks Bill!
Old 07-02-2012, 03:31 PM   #6
jorge0886
Member#: 269257
2011 STI Limited
Mind taking a look at my log?
If I'm correct, it seems to be right on target.
Thanks
https://docs.google.com/spreadsheet/...lMxYUpUbWtRVWc
Old 07-03-2012, 09:13 AM   #7
Cobb Tuning
Member#: 4803
Thanks
It looks good, but I would make sure you aren't overboosting by more than 1 psi in higher gears (5th and 6th), in situations where you would likely go wide open throttle.
Bill
Old 07-03-2012, 05:20 PM   #8
jorge0886
Member#: 269257
2011 STI Limited
How can I control that? Selecting the Low Wastegate map?
Thanks again Bill
Old 07-05-2012, 10:10 AM   #9
Cobb Tuning
Member#: 4803
Thanks again Bill
Yes, if you found you were overboosting in higher gears, you could download the low wastegate (LWG) map from the maps section at cobbtuning.com. Then use the AccessPORT Manager software to transfer it to your AccessPORT and then reflash to the car.
Bill
2010 Legact GT - Stage 2 vs. Stage 2+TMIC vs. Stage 2+TMIC custom mapped Innovative Tuning Proven Power Bragging 13 01-24-2012 05:59 PM
06 Stage 2 LGT vs 06 Stage 2 STI Lol Slow Off-Topic 162 01-12-2012 02:01 AM
Stage 2 91 vs. Stage 2 93 Rykenma AccessPort 1 12-14-2011 05:48 AM
torqued performance stage 2 map vs cobb stage 2 map 08rexguy Engine Management & Tuning 7 10-25-2011 09:58 PM
TXS stage 2 Unichip vs Cobb Stage 2 Access ECU ezatnova Engine Management & Tuning 8 02-09-2004 08:54 AM
