Old 06-30-2012, 02:08 PM   #1
Whitenukl
Member#: 305215
Default Cobb V2 question
I have searched first off which leads me to this question...if I have a ringland failure, will my access port show a code? Thanks in advance
Whitenukl is offline   Reply With Quote
Old 06-30-2012, 02:12 PM   #2
jts749
Member#: 281293
2006 WRX CGM
1993 Saturn SC2 turbo
You should get a misfire code for a cylinder with a broken ringland.
jts749 is offline   Reply With Quote
Old 06-30-2012, 03:05 PM   #3
RoadKillDMD
Member#: 284792
2011 STI
Blurple
^^ Ring land failures won't necessarily throw a code. You'll experience excessive oil consumption, smoke at start up, smokey blow by with the oil filler cap off, etc etc. I don't think the car nor the AP can detect if there is low compression in a piston. However, you may experience detonation followed by a CEL. This detonation can cause the ring land failure.
RoadKillDMD is offline   Reply With Quote
Old 06-30-2012, 04:16 PM   #4
Whitenukl
Member#: 305215
I get excessive oil consumption. But no smoke on start up or under load or boost. Did the oil cap test, no smoke blowing out of the hole. No cel. But I can't diagnose why the car is stalling out and idle is bad. Cant find any vacuum leaks, cleaned the maf, and it's not throwing any codes. On cold starts its blowing oil outta the exhaust but i just asssumed its just running rich. I'm gonna take it in tomorrow to a shop and have a compression test done. Thanks guys
Old 06-30-2012, 05:25 PM   #5
Whitenukl
Member#: 305215
Sorry about that. It was originally an AP question. So is there an answer? It will or won't? Can anyone else chime in since I've got 1 yes and 1 no answer please.
Old 07-01-2012, 10:25 AM   #6
Cobb Tuning
Member#: 4803
No, you generally won't get any diagnostic trouble code with a busted ringland. Loss of compression may eventually get to the point to cause a misfire, but a misfire code can have many other causes as well. However, you do tend to see large unexplained knock corrections (including a drop in the dynamic advance multiplier - DAM) with a broken ringland that does not improve with more conservative maps (or higher octane gas). The only way to determine for sure, though, is to get a compression/leakdown test of the motor.
Bill
Old 07-01-2012, 02:34 PM   #7
Whitenukl
Member#: 305215
^^^thanks for your help
Cobb AccessPORT V2 question..? 801wrx AccessPort 3 03-23-2012 11:53 AM
Cobb AccessPORT V2 question..? 801wrx AccessPort 2 03-12-2012 06:36 PM
Quick question about Cobb V2 compatibility Scott_2.5TS AccessPort 2 09-01-2011 03:01 PM
WTB: Cobb V2 accessport 04-07 STI, Cobb catless downpipe MarkRx TXIC Private Classifieds 1 08-17-2011 09:58 PM
FS : in WA, Cobb v2 AP (AP-SUB-003) and AVO v2 TMIC DGMLGT07 NWIC Private Classifieds 3 05-06-2011 08:07 PM
