Old 07-06-2012, 12:06 PM   #26
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
if you do a search for a homemade boost leak tester, it will have an exact layout of what needs to be purchased, how to assemble it, and how to actually perform the test.
amalgrover is offline   Reply With Quote
Old 07-06-2012, 04:05 PM   #27
wayward167
Member#: 253998
13 BRZ
found stuff on 3gwrx......found two lines that while idk if they were leaking they were at least not as tight as i would like.
still didn't hear anything definitive.
wayward167 is offline   Reply With Quote
Old 07-06-2012, 04:50 PM   #28
amalgrover
Member#: 183480
2009 Forester XT
are you 100% stock or do you have some aftermarket parts?
Old 07-06-2012, 05:26 PM   #29
wayward167
Member#: 253998
13 BRZ
lol.....almost everything except the turbo and inlet.
ebcs
intake
tbe
uppipe
crosspipe
turbo blanket
tmic
bpv
checked all the intake side stuff that could cause this aside from the inlet itself ripping.
Old 07-06-2012, 07:44 PM   #30
amalgrover
Member#: 183480
2009 Forester XT
what intake do you have, what tbe, and who does your tuning?
Old 07-06-2012, 08:10 PM   #31
Cr4ckfi3nd
Member#: 269647
2009 LGT Limited
This..... happens more than you might think
Cr4ckfi3nd is offline   Reply With Quote
Old 07-06-2012, 09:16 PM   #32
wayward167
Member#: 253998
13 BRZ
Invidia tbe Cobb SF intake, medamullet
I'm sending him a log tomorrow and we'll see what's up.
Old 07-06-2012, 09:17 PM   #33
wayward167
Member#: 253998
13 BRZ
Haven't touched prior to today and the car is relatively new.... possible but not likely
Ignition Timing and AFR's 555 Engine Management & Tuning 2 01-02-2005 04:02 PM
AFR's hondaeater69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-15-2004 08:06 PM
what are some normal healthy AFR's for a stge 4 wrx? blackie Engine Management & Tuning 3 10-01-2004 04:31 PM
Spiraling AFR's when pumping the brakes at idle... TexRex2002 Engine Management & Tuning 5 06-30-2004 12:57 AM
Crazy AFR's Big Turkey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-22-2004 12:48 PM
