#1 |
Member#: 264443
SCIC
Vehicle:2011 WRX Sedan Stg 2 OBP |
This is the result of the log with Stage 1 ACN91 Normal WG.
https://docs.google.com/spreadsheet/...FRGTHJjY3FXcEE From the looks of it, its similar to nappynick's 1st run. Do you agree that I also need ACN91 HWG?
#2 |
Member#: 286573
BAIC
Vehicle:2006 WRX OBP 16G-XT 310whp/330wtq |
doesn't look like you need the HWG map, but I cannot remember what the stg 1 peak boost target is for an '11.
#3 | |
Member#: 264443
SCIC
This is the result of Stage 1 ACN91 High Wastegate
https://docs.google.com/spreadsheet/...TR1S2FQYl91YUE According to COBB: Quote:
#4 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#5 |
Member#: 264443
SCIC
Thanks for checking it out. You have other feedback from the log besides the target boost?
#6 |
NASIOC Manufacturer
Member#: 4803
#7 |
Member#: 264443
SCIC
Cool deal. Thanks!
#8 |
Member#: 264443
SCIC
A week from my 1st Log, it looks like the boost has exceeded the target. Should i switch down to normal wastegate? Or is it normal for boost to go up and stick to HWG?
https://docs.google.com/spreadsheet/...nUwYkR2czRldkE |
#9 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#10 |
Member#: 264443
SCIC
Looks to be consistent after 2 weeks from 1st run. Guess gonna wait until winter and start logging again.
https://docs.google.com/spreadsheet/...245b0dsR25MTEE |
#11 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#12 |
Member#: 264443
SCIC
Looks like during the winter time i have to switch to Normal WG.
Do you agree Bill? https://docs.google.com/spreadsheet/...0VMY1ZNWlR3X3c |
#13 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#14 |
Member#: 264443
SCIC
Ok, ill see if I can do another test log with hwg and see if there's a huge difference.
#15 |
Member#: 264443
SCIC
Here is my log for HWG 53F degrees during the winter time. It looks like I can use HWG as well. Although it will be short lived since I'm going Stage 2 tomorrow (Catted DP and Catback exhaust). But here's the log anyway
![]() https://docs.google.com/spreadsheet/...WctZzhMT2pnM2c |
#16 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#17 |
Member#: 264443
SCIC
Stage 2 Normal Wastegate
https://docs.google.com/spreadsheet/...Wo5M0puU0ZiNHc Yikes, seems way to low in boost. Agree i have to switch to HW? One thing to consider, i currently do not have a heat shield installed since I was not aware that the dp will require an aftermarket, i ordered a heatshield but will not arrive for 2-3 days. Should I leave it in Normal wastegate to be more conservative and not increase the heat? Last edited by 11SubieWRX4D; 01-13-2013 at 10:52 PM. |
#18 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#19 |
Member#: 264443
SCIC
Thanks Bill, I know I can always depend on you. Do you know why my boost is way too soft and during winter? Will it be an issue during the summer when I can't go over high wastegate and under boost will be an issue? Is this a normal occurrence?
#20 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#21 |
Member#: 264443
SCIC
Ok, here is my log with Stage 2 HWG ACN1. Looks good? Should i also be concerned about the feedback knock?
https://docs.google.com/spreadsheet/...DAxXzF2UFpRS0E |
#22 |
Member#: 264443
SCIC
Did an incomplete log since i hit traffic this morning
. I only got up to 4300 RPM. https://docs.google.com/spreadsheet/...UIxNE1HYXZxeEE Looks good in the beginning, but would like to go up to 7000 RPM to ensure no knock comes up. My log above had knocks during low RPM. Chance that i would see that again? |
#23 |
NASIOC Manufacturer
Member#: 4803
You have a couple of threads with the same logs - I would stick to one of them as it gets confusing to follow the info in both threads at the same time.
Bill |
#24 |
Member#: 264443
SCIC
Yea sorry. I'll continue on the other log since I'm already on Stage 2.
| Thread Tools | |
| Display Modes | |
| 2011 WRX Stage 1 + AEM 93 Data Log | Game_Over | AccessPort | 19 | 07-17-2012 09:23 AM |
| 2010 WRX Cobb Stage 1 93 OTS Data Log | KPunk | AccessPort | 2 | 05-13-2012 09:50 PM |
| 2011 WRX COBB stage 1 + SF 93 octane Log Check | subiebosch | AccessPort | 4 | 04-30-2012 09:57 AM |
| 2012 WRX Cobb Stage 1 ACN 91 data logs | Knale | AccessPort | 3 | 04-24-2012 09:05 AM |
| 2011 wrx stage 1 acn91 data log assist - overboosting? | mattesonb | AccessPort | 9 | 02-10-2012 07:36 PM |
