Old 07-01-2012, 07:56 PM   #1
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
Default Are rear diff bushings pointless if I install subframe lockdown bolts?
I had been contemplating installing some rear subframe diff bushings, but believe rear subframe lockdown bolts will be more effective at killing the rear diff thump on hard acceleration.
Because the lockdown bolts bypass the subframe bushings, am I correct in believing Whiteline/Kartboy rear diff subframe bushings would be a complete waste of money?
Smurftastic is offline   Reply With Quote
Old 07-01-2012, 08:24 PM   #2
jamal
Member#: 71875
98 2.5GT
my wheels fit
Depends which bushings. Replacing the ones that hold the subframe itself to the chassis aren't really worth it with bolts, but outrigger and diff bushings are still going to make a difference.
jamal is offline   Reply With Quote
Old 07-01-2012, 08:43 PM   #3
Splinter888
Member#: 215962
2006 Wrx
SGM
Probably better off just buying Unabombers sexy rear end kit from TIC and saving some money on the package. Every little bit helps.
Splinter888 is offline   Reply With Quote
Old 07-01-2012, 09:58 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
do NOT get the 'race' or 'enthusiast' bushings unless you are hard core!!!!
you have been warned
Old 07-01-2012, 10:23 PM   #5
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
I am currently thinking about just getting the lockdown bolts and see how the thumping responds. If that doesn't do the trick, added outriggers should perfect it.
Old 07-01-2012, 10:36 PM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
you should read up on installing the lockdown bolts
odds of the captured nut breaking off when you try...TRY to install them are quite high in a car that old unless you take EVERY precaution
and even then....id give ya 50/50 on getting them both in properly....maybe 60/40
Old 07-01-2012, 11:04 PM   #7
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
I have researched, and definitely intend to follow every precaution to a T.
I may be one of the only people on NASIOC as comparatively paranoid about things going wrong as you
Old 07-01-2012, 11:24 PM   #8
Splinter888
Member#: 215962
2006 Wrx
SGM
Get the comfort bushings, If you do go with unabombers, I believe you have to call and request the comfort ones because "enthusiast" are standard. Pretty sure its possible
Old 07-02-2012, 01:42 AM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
the lockdown bolts dont really do anything for the 'thump'....the bushings DO
Old 07-02-2012, 09:13 AM   #10
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The diff bushings and subframe lock bolts do two totally different things. The bolts keep the subframe from shifting under cornering. The bushings help keep the differential from moving around under accel and decel. If you are getting thumping under load you need the bushings over the bolts. Or you can get our entire kit that the two bushing sets and bolts.
Tony
Turn in Concepts is online now   Reply With Quote
Old 07-02-2012, 12:48 PM   #11
sjs0433
Member#: 86061
^Just get the entire kit from those guys.
sjs0433 is offline   Reply With Quote
Old 07-02-2012, 04:52 PM   #12
Smurftastic
Member#: 243697
02 Stg2+ WRX
Top Scoob 031
A big thanks to TIC and Uncle Scotty for taking the time to clarify this issue for me. While reading up on the subframe lockdown bolts, I came under the impression that the bolts negate subframe movement in ALL directions - I clearly need the bushings to fight the evil thump!
Old 07-02-2012, 08:01 PM   #13
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
i would find a thread chaser in the size and length that the bolts are...
and get a quart of cheap dexron ATF and a quart of acetone and an empty quart motor oil bottle....pour half the dexron atf in the oil bottle and then half the acetone....then pour the rest of the acetone in the atf bottle....use that as penetrant/lube for the thread chaser....and S L O W L Y work the chaser in the captured nut for the bolts...
Old 07-09-2012, 12:12 PM   #14
JohnnyG
Member#: 164671
2009 WRX 265
JohnnyG is offline   Reply With Quote
DIY Rear subframe lockdown bolts. chet.wrb Brakes, Steering & Suspension 73 12-07-2012 02:04 PM
DIY Rear subframe lockdown bolts. chet.wrb General Community 14 05-18-2011 07:33 PM
Leave in Rear Subframe Lockdown Bolts forever? paulpat Brakes, Steering & Suspension 11 01-03-2011 10:42 AM
Help with subframe lockdown bolt install kmook Brakes, Steering & Suspension 11 10-19-2009 12:03 AM
Group N tranny mount vs rear diff bushings vs subframe lock bolts shotoyan Transmission (AT/MT) & Driveline 31 12-29-2005 09:40 PM
Message Board Statistics All times are GMT -4. The time now is 01:55 PM.
