Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 07-01-2012, 10:41 PM   #1
02skoobywrx
Member#: 312035
Default Electrical questions on ls1 swap
I've put an ls1 in an 02 wrx and had some questions. I've noticed the thicker wires that go to the alternator dont go directly to the battery, they run into the main fuse box. Should I hook that up to the ls1's alternator instead of just running a wire from the alt. to the battery?
Wheres the best place to tap into for an ignition hot wire? Is there any in the main fuse box? Its just going to be a signal wire to turn on the relays for the ls1's harness. It has to have power while the starter is turning too because its powering the ls1's ecu and harness. And whats the best way to tap it so its reliable?
And lastly, what does the main relay power? It wouldn't de-energize and was keeping the fuel pump relay energized so I unplugged it (main relay) and now the fuel pump relay works correctly. I can't seem to find anything that is affected by the missing relay.
02skoobywrx is offline   Reply With Quote
some question on engine swap on a GC8 V6 Subaru Conversions 4 05-18-2005 07:32 PM
Question on cluster swaps JDM_Scobaru Mid West Subaru Owners Club Forum -- MWSOC 2 02-03-2005 10:51 PM
Rear diff technical question on 6sp swap. Having some issues. Kwyjibo Transmission (AT/MT) & Driveline 4 08-04-2004 03:13 AM
some questions on EJ20 swap MeshmeZ Subaru Conversions 7 04-21-2004 10:36 AM
question on engine swap spacemonkey Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-02-2002 01:33 PM
