Old 07-08-2012, 02:39 AM   #26
rob1n1
Member#: 276425
2013 335is
Alpine White
Originally Posted by babykid278 View Post
This has to be the worst photo for checking out wheel gap in the history of cars...
rob1n1 is offline   Reply With Quote
Old 07-08-2012, 08:16 AM   #27
hcancino
Member#: 261113
It could have been taken at night
hcancino is offline   Reply With Quote
Old 07-08-2012, 09:23 AM   #28
babykid278
Member#: 323606
2011 WRX
Originally Posted by XsoberX View Post
^ I hate pictures like that. I can't see anything... Perfect, black wheels, black tires, in a black wheel well. Get some light on that thing! Were looking for fender gap, not window tint!
Back on topic, plenty of people have stated it... Turbo back or just a down pipe, tune, and you're set. And although everyone will disagree with me (aside from people who have actually done it), an intake seems to add a good 20-30 ft/lbs, as long as you're tuned for it.
sorry for bad pic. This pic should be let you know how it looks with RCE spring. Not much drop.
babykid278 is offline   Reply With Quote
Old 07-08-2012, 05:39 PM   #29
rexblake
Member#: 178426
2010 S4
Gray
As stated, dp and tune. And the car looks nice, but as stated as well, most springs don't help much in the handling department. Some actually make it much worse. Personally, I have no experience with those springs, so I don't know if they are good or not, but I'd highly recommend calling some quality vendors and seeing what they suggest for suspension. Check out Turn In Concepts, they have a good rep.
rexblake is offline   Reply With Quote
Old 07-09-2012, 12:51 AM   #30
Tom Hartz
Member#: 225284
2011 Impreza WRX
Spark Silver Metalic
Originally Posted by o0Spoony0o View Post
stiffer rollbars front/rear are a better handling mod than slamming your car.
By a lot, most lowering kits make your suspension geometry worse. Yes I know it looks "cool" to be dragging your wrx along the pavement like every VW out there...but you're not improving your car's performance.
This is what I am going to do. I drive my car allot, like 24,000 miles a year and I don't want a stiff ride.
Tom Hartz is offline   Reply With Quote
Old 02-22-2013, 04:08 PM   #31
WRXSWP
Member#: 347936
2011 WRX
currently, I have WRX 2011 and I also a stage 2 set up with:
+ CBE
+ Down Pipe
+ CAI
Do i need a Boost Solenoid, fuel pump and injector for this set up?
WRXSWP is offline   Reply With Quote
Old 02-22-2013, 04:25 PM   #32
nfm
Member#: 171697
05 WRX
Stiffer swaybars should be used to adjust oversteer/understeer AFAIK. I would get stiffer springs.
nfm is offline   Reply With Quote
Old 02-22-2013, 04:37 PM   #33
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Sway bars do essentially act like springs in a corner, or at least for the outside wheels, they do. Instead of a spring compressing, the bar is flexed, but both limit suspension travel, and therefor change in geometry, and therefor tire contact.
The reduced body roll is also welcomed, and lends itself to greater cornering confidence.
As far as bumps go, sway bars DO increase ride stiffness if you hit a bump with half of your car. The left and right suspension are in 'disagreement' when you hit a pot hole or similar, and therefor the sway bar will provide resistance. This is why rally cars often don't even have sway bars.
blehhh is offline   Reply With Quote
Old 02-22-2013, 04:39 PM   #34
2011rexowner
Member#: 280094
2011 sti limited
Wrb,lots of upgrades
Also, not that most people care, but ask what kind of dyno there using as different dynos will give you the "numbers" your looking for. I prefer a mustang dyno because it reads lower. I personally just feel its a more accurate number. From what I've read all over other forums its like a 12% difference between a mustang dyno and dyno jet.
2011rexowner is offline   Reply With Quote
Old 02-22-2013, 04:57 PM   #35
S1CkWrx
Member#: 325249
2012 wrx
dgm
+ CBE
+ Down Pipe
+ CAI
it wouldnt hurt to have them. FP get DW65c its a direct swap no cutting what so ever!
and Grimmspeed EBS.
S1CkWrx is offline   Reply With Quote
Old 02-22-2013, 05:32 PM   #36
WRXSWP
Member#: 347936
2011 WRX
and Grimmspeed EBS.
So I can either have them or not rite? What is different if I have them in my set up and dont have them in my set up. THanks
Old 02-22-2013, 05:45 PM   #37
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
fp is just install and go. the ebcs needs a tune special for it.i have the grimmspeed ebcs. nice piece. that fp and injectors are my next mods.
424wrx is offline   Reply With Quote
Old 02-22-2013, 05:49 PM   #38
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
and Grimmspeed EBS.
I hate when people say this, have you actually done the DW65c fuel pump install? You're right no cutting but its absolutely the worst thing I've ever had to install on my car. You need 2 people minimum and you have to be gentle and firm at the same time when doing this install. Honestly just pay someone to do this install. If I knew what it entailed before I started doing it I would have.
freddy121389 is offline   Reply With Quote
Old 02-22-2013, 07:42 PM   #39
StackSmasher
Member#: 316928
2012 STI limited
really?? I just looked up the install instructions and does not look hard whatsover. the reviews on rally sport have several people saying it was incredibly easy and it took about an hour...
what part did u have issues with?
StackSmasher is offline   Reply With Quote
Old 02-22-2013, 08:30 PM   #40
snowboarder2587
Member#: 322407
2012 WRX Limited
Plasma Blue Pearl
The RCE springs that the OP is running (I'm assuming to bee the RCE blacks) were highly recommended to me by TiC to improve the performance.
snowboarder2587 is online now   Reply With Quote
Old 02-22-2013, 08:38 PM   #41
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
rce are amazing springs. i have the whole racecomp setup. just dont throw springs on stock struts. they are underdampened.
Old 02-23-2013, 05:34 PM   #42
S1CkWrx
Member#: 325249
2012 wrx
dgm
dont be a negative nancy, its very straight forward and simple i rather have a stumble instead of hacking apart a housing. ive done several for a few members of my area alone. never an issue.
