Old 05-20-2012, 09:38 PM   #1
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Default IAT Compensation - Blow Through
Hello,
I recently have installed a custom blow through setup on my Forester with a Borg Warner S261. I notice that when I park the car after the engine is hot, and then start the car, the afrs will drop and run very rich. My question is can I just 0 out the IAT Maf Compensation table since the sensor will be reading actual temperature or should I decrease the table by some percentage. I'm not sure how I should approach this so some input would be appreciated.
scootarida1 is offline   Reply With Quote
Old 05-20-2012, 10:57 PM   #2
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well the pipe is heat soaked from the radiant heat off the engine so it will take a quick drive to get it to cool down. personally i wouldnt put them at zero. maybe decrease them a bit. then wrap your cold pipe and see if that helps with keeping the temps down. make sure its the silver/shiney wrap so it blocks the heat. std pipe wrap w/o the reflective outer part wont work.
WhiteBgeye02 is offline   Reply With Quote
Old 05-21-2012, 07:21 PM   #3
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
Okay, I might try lowering them a tad and see if it helps.
Old 05-22-2012, 08:17 PM   #4
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
yeah like i said though there is the compensation there for a reason but since you have post intercooler temp sensing you have more control compared to the draw through were intercooler heat soak has a huge affect but isnt taken into the calc until knock occurs. should be a good way to fine tune the car.
Old 05-31-2012, 06:08 PM   #5
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
I did not end up changing the IAT Compensation yet but I ran into a scenario where only when it rains, the car goes into a very quick afr swing from 14.4-15.2ish on the wideband during idle. Almost sounds like its cammed. During normal weather, the idle is spot on. Im thinking the IAT Comp is effecting this. Any thoughts?
Old 06-11-2012, 03:34 PM   #6
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
sounds like a bad coil pack... I normally make the IAT compensation less but still leave the higher/Lower values the way they are. if the IAT is actually reading 120F or 140F i want to take out some timing... at the same time if its 20 degrees out in MA i dont mind adding a bit more timing.
Bamofo is offline   Reply With Quote
Old 06-11-2012, 03:43 PM   #7
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I had to make some massive changes to my IAT compensation when I went blow through, high temps would cause it to swing very rich. I'm still not sure why it did this in blow through and not draw through, but either way patching up the IAT table fixed it.
Old 06-11-2012, 05:33 PM   #8
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
so basically making the adjustments less extensive then?
Old 06-11-2012, 05:52 PM   #9
Member#: 51961
2005 STi
2012 WRX
Actually I had make the adjustments very large. This is how it ended up looking (stock vs modded):
Old 06-20-2012, 10:36 PM   #10
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Very interesting suicide! I'm having this issue but mine swings lean when temps go up which in turn causes my fuel trims to be erratic! How did you narrow it down to specific cells? Did you log iat, corrections (a,b,c,d), and afr? Seems like you'd have to log quite a bit to pick your compensations for each cell like you did!
wgr73 is offline   Reply With Quote
Old 06-21-2012, 12:43 AM   #11
Member#: 51961
2005 STi
2012 WRX
I ran straight open loop fueling, then logged AFR error vs MAF and IAT for different atmospheric temps. It took a while to nail down, but I started seeing improvements almost immediately. It probably took longer than it should have because I greatly underestimated the magnitude of the changes I ended up needing to make.
Old 06-21-2012, 09:18 AM   #12
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Cool. It would seem like it'd take a while. Crazy how huge the compensations are! I'm working on mine right now....the furthest two columns are set at 10% and 12% respectively. I'll probably have to change this later.
How are your fuel trims now?
Old 06-21-2012, 10:07 AM   #13
Member#: 51961
2005 STi
2012 WRX
I don't use AF Learning, but my AFR was good apart from the throttle dependent MAF readings that never went away. So a couple weeks ago I switched to speed density and am now working on dialing that in.
Old 06-21-2012, 11:08 AM   #14
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Never?...You always run OL? Interesting. I'm on speed density/maf blend as well, and this issue is apparent. The car runs awesome and is very fluid, it just kills me looking at the learned fueling.
Old 06-21-2012, 12:44 PM   #15
Member#: 51961
2005 STi
2012 WRX
I was running straight OL for a while, but a while back I switched to CL, just with no learning (forced min/max AF Learning to 0).
Old 06-27-2012, 10:24 AM   #16
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Gotcha. That's not a bad idea. I should try that for a while and see how it works. My eyes are glued to the wideband so the transition to it should be ok. I do like the fact that AF learning can help if there's a small change in fuel/air (leak)
Old 07-05-2012, 05:51 PM   #17
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
so basically you just fine tune it based on the wideband rather than let the car do af learning and compensation?
Old 07-05-2012, 06:41 PM   #18
Member#: 51961
2005 STi
2012 WRX
Yes, because the AF Learning can do some nasty things. Most people disable the D range learning, I just disabled the whole thing.
Old 07-06-2012, 03:41 PM   #19
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
ill have to give that a try and see what I can come up with.
Blow through MAF - after turbo but before intercooler MY99 2.5GT Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-04-2007 09:46 PM
FS: Ultimate Racing Blow Through MAF Housing - $150 InfamousDX Private 'For Sale' Classifieds 31 06-25-2006 05:59 PM
FS: Intakes and blow through maf - Perrin short ram, BIG maf, K&N.... 2theMAX Private 'For Sale' Classifieds 12 02-15-2006 12:19 AM
Blow through maf set up majnthr33 Mid West Subaru Owners Club Forum -- MWSOC 9 09-19-2005 10:01 AM
Blow Through MAF users! Javier Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-29-2005 10:15 AM
