Old 07-04-2012, 03:47 PM   #1
02subydoo
Member#: 325104
Matte Black
Default can i run stage 2?
ok so right now i am running stage 1 93 octain. however i have a strait catback(no resanator, no muffler). i also have a short ram intake. the exhaust's lack of backpressure (to free flowing) i believe is causing me not to reach peak boost. can i run stage 2 even though i have the stock down pipe, what would happen if i did run stage 2 with stock dp.
02subydoo is offline   Reply With Quote
Old 07-04-2012, 06:42 PM   #2
04Silverex
Member#: 77322
2011 WRX
SSM
I wouldn't run the stage 2 map, the stock down pipe will not flow the same as an aftermarket dp.
04Silverex is offline   Reply With Quote
Old 07-04-2012, 06:51 PM   #3
habitatxskate
Member#: 197537
06 WRX
matte black
Don't do that.... They have maps for 02-05 that resolve your problem, "low wastegate map" or something like that
Edit: on cobb's site
habitatxskate is offline   Reply With Quote
Old 07-04-2012, 08:41 PM   #4
02subydoo
Member#: 325104
Matte Black
Post
Thank you! ok i will wait for the downpipe, but what would happen if i didnt, not that i am im not. but the thing is is i tried the high wastegate map for the car and it actually made it worse. with the regualar stage 1 i was hitting about 8.6 pounds of max boost and with the high wastegate only like 7.2 or so.
Old 07-04-2012, 09:23 PM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Take the SRI off and put the stock airbox back on...
wrxdrvr is offline   Reply With Quote
Old 07-05-2012, 10:33 AM   #6
Cobb Tuning
Member#: 4803
Stage 2 is only for an aftermarket downpipe. If anything, besides not being appropriate for your car, you will likely boost less with a stage 2 map vs. stage 1. There are many reasons why you could be under your target. Do you have a version 2 (gray with color screen) or version 1 (black with b&w screen) AccessPORT? If you have a version 2 AccessPORT, best thing to first get a 3rd gear data log as described in the video below (if you can do so safely).
Also, as mentioned, you want to make sure that you are running an intake that is compatible with the map you are using. I assume this is an 02 WRX, in that case, only the Cobb SF or stock intake is compatible with our 02-05 WRX OTS maps. Using a different intake with an incompatible map can possibly result in the improper airflow being determined by the MAF sensor, resulting in the incorrect fueling and ign. timing and, worst-case, potential engine damage. You can, however, get a custom tune through one of the tuners in our protuner network for the intake.
Bill
