![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 158864
let's assume for a moment that i could get some seriously high offset wheels in 5x114.3. i'm talking anywhere from +63 to +72.
i could run these on some 5x114.3 spacers assuming they were only 15mm (or whatever) thick. my question becomes, can this actually be done safely (i'm willing to get some high-tensile lugs/nuts to do up super tight if need be).
#2 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, '11 A4 Crystal Gray, Silver |
Since your goal is to get the wheel to a decent offset that works well, I don't see why there be a problem. Of course you'd need extended studs. I would rather have a spacer with extended studs than one with the studs pressed in. Studs pressed into steel are going to hold up better than studs pressed into aluminum. And make sure you get some quality spacers are are hub-centric for both the hub and the wheel.
On the other hand, you'd putting a band-aid on a problem that you don't really have to have. Just get wheels that have the correct offset. |
#3 |
Member#: 97135
NWIC
But......why??
#4 | |
Member#: 158864
mavic - i'm not sure why i would need extended studs? if anything i would have thought they'd have to be shorter so they didn't stick out past the spacer that the 5x114.3 ones are pressed into? Last edited by vicious_fishes; 07-05-2012 at 09:34 PM. |
#5 | |
Member#: 97135
NWIC
As far as the spacer goes, oem would be fine if you use 20-25mn bolt on's, or use extended studs and slip on's if smaller. |
#6 | |
Member#: 158864
i'd ideally run a 15mm adapter/spacer on the +63. |
#7 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 WRX Wagon |
Depending on which Subaru you have, it may be more practical to just convert to 5x114.3 hubs.
#8 | |
Member#: 97135
NWIC
#9 | |
Member#: 158864
which can be easily fixed with the right spacer. however, the +48 has been fitted to numerous subaru's without issue so i'd say that's as high as you can go. |
#10 | |
Hoodbridge!
I still say...not worth it. Oh, and I've wanted to get some of those 949 racing 6ulr wheels in 5x114.3 +48. Apparently they won't be available until fist quarter next year. ![]() |
#11 | |
Member#: 158864
as you can see it's only $170/wheel. considering they're here on the shelf and 50% off, i'm sure if you bought them you could just get them sent over and still be $ and months in front of where you would be. |
