Old 07-05-2012, 08:30 PM   #1
AndrewFD3
Member#: 210458
2003 wrx built ej207
Rally blue
Default Ej207 P0390
Hello to all,
I have been trying to diagnose this for some time and I am getting frustrated. My v7 is fully built, stock heads, functional avcs. Now the issue is whenever I bring it passed 7K a cel comes on for P0390 B Circuit Bank 1. I have checked all the wiring, and replaced the avcs sensors and cam sensors and issue still occurs. Anyone have any input? Any help will help, thanks.
-Andrew
AndrewFD3 is offline   Reply With Quote
Old 07-06-2012, 03:04 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
That cel is for circuit malfunction. Double check the connectors for cam sensor. Also check continuity of circuit with multimeter. Might have to replace that sensor.
Old 07-06-2012, 03:06 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
The jdm cam sensor is different than usdm..as you probably already know.
Old 07-06-2012, 03:38 AM   #4
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
I am guessing ur using the jdm ecu?
Thran is offline   Reply With Quote
Old 07-06-2012, 08:51 AM   #5
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Lazy subscribe. I have similar issue and am going through the process of tracking things down. What do your AVCS logs look like when the CEL pops?
OppositeLock is offline   Reply With Quote
Old 07-06-2012, 12:34 PM   #6
AndrewFD3
Member#: 210458
Rally blue
Yup using jdm ecu, changed cam sensors with (jdm)
Old 07-07-2012, 10:35 PM   #7
OppositeLock
Member#: 54060
Any logs of the AVCS when the CEL is on? If so, can you post them?
Old 05-17-2013, 05:55 PM   #8
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
Bump, would like to know if anyone was able to solve this since I'm having the same issue.
N'CTRL is offline   Reply With Quote
Old 05-23-2013, 12:48 PM   #9
N'CTRL
Member#: 29871
Metallic
...anyone? I'm going to try to go through the AVCS wiring this weekend but this is still an intermittent problem. I haven't gone much into boost when the CEL is on but I assume its ok to drive like this until I resolve the problem. The car feels normal under regular driving conditions but I won't risk going WOT.
Old 05-23-2013, 04:44 PM   #10
OppositeLock
Member#: 54060
Mine turned out to not be intermittent. It was fixed by swapping two AVCS wires at the ECU plug.
Old 05-24-2013, 09:39 AM   #11
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Mine was s loose input by the strut tower...turbo being big hit it causing the pin to come out.
Coop1103 is offline   Reply With Quote
