![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 226523
SCIC
Vehicle:2006 STI SGM |
Just bought some rays valve stems an need guidance on install... Thanks
#2 |
Member#: 123375
Vehicle:00 Impreza 2.5RS Its all BRP again. |
Rays valve stems? The only way to install new valve stems is to break the bead on the tire, rip out the old ones and re-seat the bead. Any tire shop would do this for you. I've broken tires down with tire irons and it sucks having a shop do it is worth the price.
#3 | |
Member#: 226523
SCIC
#4 |
Member#: 123375
Either way the tires gotta come off all valve stems install from the back of the rim face. Bring it to a tire shop and have them install em.
#5 | |
Member#: 226523
SCIC
#6 | |
Member#: 97135
NWIC
Stick the stem in the hole, one washer outside (unless it has a rubber grommet), washer and grommet on inside, torque the **** outta them and call it good. |
#7 | |
Member#: 226523
SCIC
#8 |
Member#: 325282
Dear the best way to install new rays valve stems is to replace with old ones. If you have no idea, then do not take any risk. Just go to car specialist and solved your problem. He does it against little charges.
