Old 07-06-2012, 09:50 AM   #1
jorge0886
Member#: 269257
2011 STI Limited
Default Is a lag normal at 2800rpm
I'm stage 2 with stock exhaust, SF intake, up pipe, downpipe, and Stage 2 OTS normal wastegate 93oct map
I've noticed it mostly in 6th gear when accelerating to 3000rpms, RIGHT at 2800 if I let off the throttle there is a subtle jerk and kind of pull away from power.
Is this common?
jorge0886 is offline   Reply With Quote
Old 07-06-2012, 10:03 AM   #2
Cobb Tuning
Member#: 4803
Is this common?
How much throttle are you giving it when you are accelerating vs. when you let off?
Bill
Old 07-13-2012, 11:51 AM   #3
jorge0886
Member#: 269257
2011 STI Limited
When accelerating, I am giving <50% throttle, right as I near 3000rpm (gear does not seem to matter), if I let off the gas to approx.<40% I feel a tug from the car and the power seems to be pulled away for a second
Old 07-14-2012, 08:35 AM   #4
Cobb Tuning
Member#: 4803
The 08+ STis do have an issue in that general area which is usually described as a hesitation (more when you are on the throttle than getting off the throttle). This is thought to be due to the OEM FPR set-up on these cars (relative to other Subarus) and different cars can have different degrees of severity. You can verify if this is the problem by getting a data log when the problem occurs (use the default log list plus add A/F Correction 1). Check out our data logging video below.
Bill
