Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Old 07-06-2012, 12:44 PM   #1
AJW Performance
Vendor Sales Rating: (38)
Member#: 219896
Default Defi, STRI, AEM, SMY, ATI, EBCS by Perrin, GrimmSpeed and Cobb. Shop here
We distribute SMY Clustermaker products for the 08+ WRX/STi and 09-10 Forester. Soon to come will be the 02-07 Cluster! Check out our site for some insane combos on gauges. Dont see what you need? Just give us a shout.
http://ajwperformanceproducts.com/store/#ecwid:category=954516&mode=category&offset=0&sort =normal
And the manufacturer!
www.smyclustermaker.com
Defi Advance CR series 52mm or 60mm Gauges
Defi-Link Advance CR 52mm gauges utilize Defi's next generation, Defi-Link Advance control unit for ultra precise monitoring and interaction. A built in warning light will illuminate if any short, sensor failure, or connection failure is detected. Defi also built in a user-determined "peak" and "warning" setting that will illuminate a light to indicate that one of these value has been reached. The Advance CR system is able to record and play back any gauge display for up to three minutes. Note that Defi-Link Advance gauges and control unit are not compatible with the standard Defi-Link system
Driving data can be stored and can be replayed up to 3 minutes Warning by buzzer sound (defeatable) when the warning LED is onRecords peak values and warning values during driving
The illumination at night can be switched between 2 different colors. (White dial: amber red / blue; Black dial: white / amber red[
Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit or serial communication error.
Available in White dial/Amber Red/Blue or Black dial/White/Amber Red](Defi-Link Advance control unit required for these gauges
2.0 Bar boost gauge
Intake Manifold Pressure Gauge
Oil Pressure Gauge
Fuel Pressure
EGT Gauge
Water Temp
Defi's Racer series
Defi's Racer series gauges will reward you with their great response and reliable readings. The gauge faces are a stealthy tinted black when the power is off. Fire up your car and enjoy Defi's signature sweeping ceremony as the gauges light up bright. Defi Racer gauges are standalone gauges as they do not require a Defi-Link Control Unit for use. The temperature gauge can be used for water or oil and the pressure gauge for fuel or oil. The Racer series are smaller, less expensive, and don't require a control unit but still have the aggressive styling and accuracy that Defi is known for. These gauges are 52mm and display in US measurement units. Now offered in 60mm
Features
The outer bezel contains a red triangle and can be rotated to be used as a visual indicator
Enjoy Defi's signature flashing and sweeping ceremony on power on / off
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Red Racer, White Racer, or Blue Racer 52mm.
Now offered in a 60mm size!!
Temp gauge
Pressure
Voltage
EGT
AEM Digital display gauges
AEM's digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels & black and white faceplates to personalize the look of your gauge; it's like having four designs in one! Each gauge includes 24 color-coded LED lights that change from green to yellow to red for immediate reference to the measured parameter as well as an integrated three-digit display that reveals real-time operating conditions
Boost
Oil Pressure
Transmission, Water or Oil Temperature gauge
Volt
Wideband UEGO and AEM Analog
AEM Tru-Boost Gauge and booster controller
The AEM Tru-Boost Boost Gauge/Controller combination is a multi-featured system for simplified, comprehensive boost control. Packaged within a 52mm gauge are a 29psi capable boost controller, peak-memory boost gauge, and many other great features. This unit includes black and silver bezels and black and white faceplates for simple color selection and easy matching to other AEM gauges (i.e. serial gauge, UEGO, etc.)
On-board pressure sensor included for boost levels up to 29 PSI
Selectable over boost alarm with overboost shutdown
Scaleable bar graph display
Selectable waste gate delay for quick turbo spool
Simple install harness allows for quick and easy installation
Boost hose and fittings included for easy hookup to on-board pressure sensor
Got some STRI Gauges and pod options too
PM for pricing
X Line Series
Boost 52mm and 60mmBlack Dial- Amber LED
White Dial- Amber LED
Smoke Lens- White LED
Smoke Lens- Amber LED
Vacuum
52mm and 60mm
Water Temp
52mm and 60mm
Oil Temp
52mm and 60mm
Oil Pressure
52mm and 60mm
Exhaust Temp
52mm and 60mm
Tachometer
52mm and 60mm
Voltmeter
52mm and 60mm
Fuel Pressure
52mm and 60mm
Digital Stepper Drive (DSD) Series
Boost:52mm and 60mm
Vacuum
52mm and 60mm
Water temp
52mm and 60mm
Oil Temp
52mm and 60mm
Oil Pressure
52mm and 60mm
Exhaust Temp
52mm and 60mm
Tachometer
52mm and 60mm
Volt
52mm and 60mm
Fuel Pressure
52mm and 60mm
  • Can also do combos like
  • stri boost/oil pressure and innovate db red wideband!
  • ATI Pods, Autometer, Defi pods and Perrin cluster pods in stock+ More
Zenesis Alarms:
We offer the best pricing possible on all Zenesis products. We will match or beat any price. ZN502's and ZN302's are always in stock so there is no down time. Shipping is always free
Zenesis ZN502 Alarm
Remote Start/ Turbo Timer w/ Zpass touch- 2xx.xx Shipped
__________________
Best Pricing and Customer Service in the Business!
Shop Line: 603-715-9076
Hours:
Monday- Friday Closed weekends
9:00 AM to 5:00 PM at shop
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Open until midnight via website/email/internet
Your Forum Reps are Allen, and Jorel!
facebook us: "AJW Performance"
Follow some of our work-
AJW Performance is offline   Reply With Quote
Old 07-06-2012, 12:53 PM   #2
AJW Performance
Member#: 219896
Perrin Electronic boost controller
The Perrin EBCS Pro is Perrin's new and improved version of their former EBCS, which replaces the factory bleed type, boost control solenoid offering an extremely fast reaction time for improved boost control accuracy. The EBCS Pro is a huge benefit for consumers with aftermarket ECU's that use the factory solenoid for boost control such as the EcuTek, Hydra, UTEC, Motec, AEM, Haltech, Unichip (custom programming needs to be done for the EBCS Pro). Add the Perrin EBCS Pro to any aftermarket ECU to provide full electronic boost control without the need to purchase a separate external boost controller. The actuator is operated by a direct-acting single-solenoid. No boost pressure is pressing on the actuator, therefore no premature boost loss can occur.
A much lower wastegate duty cycle can produce higher boost levels giving tuners more headroom when modifying high-horsepower and high boost vehicles. A built in manual override allows tuners to physically test the boost controller for added safety for your car. The Perrin EBCS Pro will also work as a replacement solenoid for all popular electronic boost controllers. Designed to handle up to 120psi, the EBCS Pro features an all new custom made valve, body and coil spring. The Perrin EBCS Pro is a universal product for factory-turbocharged vehicles and requires custom tuning for safe operation. The full Perrin EBCS Pro kit includes, solenoid, wiring harness, mounting hardware, vacuum fittings, 6ft of vacuum hose and full installation instructions
GrimmSpeed EBCS
GrimmSpeed introduces the most complete and easy to use 3-Port Electronic Boost Solenoid available on the Subaru market. This solenoid allows you to tune your OEM boost levels in a quick and efficient manner through your factory ECU. The stock boost control solenoid works fine at stock boost levels, but at elevated boost pressures will become extremely unstable and unpredictable, causing a potentially unsafe boost curve. The GrimmSpeed solenoid is designed to withstand unprecedented boost levels up to 120psi (far more than any Subaru could EVER handle)! The GrimmSpeed 3-Port solenoid is guaranteed to spool your turbo faster and maintain rock solid boost control.
Why should you run a 3-Port Solenoid over a traditional manual boost controller? A MBC does a good job with basic boost control, however it will always attempt to give you full boost at all points in the RPM range. For instance, let’s say you set your MBC to a peak boost of 18psi. The boost controller will try to hit 18psi whether you are at 2500rpm or 7000rpm. If 18psi causes detonation at 7000rpm, you are forced to lower your boost level throughout the entire RPM range which will actually reduce power in the mid range. With the GrimmSpeed 3-Port boost control solenoid, you can tune a custom boost curve through the ECU, allowing you to run the max safe boost at any point in the rev range
Cobbs all new Electronic Boost control solenoid
The Cobb tuning 3-port boost control solenoid is an excellent upgrade for your WRX or STI, enabling precise boost control in a simple package that is easy to install and tune. The Cobb 3-port boost control solenoid will eliminate boost fluctuations and boost creep that runs rampant in OEM boost control systems, providing stable and repeatable boost control for accurate tuning and consistent performance. With an operating range up to 120psi, The Cobb boost control solenoid is equally capable of providing stable boost control at stock boost levels as well as extremely high boost levels. Featuring 1/8″ low-profile corrosion resistant barb fittings, the Cobb boost control solenoid also uses high quality Viton spools and seals to ensure a long life of accurate performance. The Cobb 3-port boost control solenoid mounts in the stock location, uses a OEM harness connector and includes all hardware, brackets and photo instructions for a complete and painless installation.
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 09-26-2012, 08:39 PM   #3
ajanks112
Member#: 333018
05 Subaru
bump,,
ajanks112 is offline   Reply With Quote
