Old 08-30-2002, 02:15 PM   #1
DragonRM
Member#: 14365
Default had a fog light stop working
Hiya... got a 2000 2.5rs and one of the fog lights just stopped working... checked it with 2 bulbs I knew were good, and it isn't the fuse... was cutting in and out for a bit then it just stopped. Dunno if my dealer's shop will like me as I had hyper whites in there... but will probably replace back to stock bulbs before getting it fixed. Just wondering if anyone has heard of this problem as a common occurance or if they know a way I can fix it without having to go to the dealer The wiring all seemed ok as well...
DragonRM is offline   Reply With Quote
Old 08-30-2002, 03:02 PM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
probably fried the OE wires. I'd say buy a set of Hella 500's and be done with it.
Old 08-30-2002, 03:11 PM   #3
DragonRM
Member#: 14365
can't really afford anything like that atm hehe
Old 08-30-2002, 03:14 PM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Hella 500's are only $55-$65, by the time you analyze the problem and fix the borken wiring/etc you'll easily be out that much. Do a search on mounting options (some buy brackets, some don't).
Old 08-30-2002, 05:42 PM   #5
DragonRM
Member#: 14365
hmm... do they have any probs with fog light covers? I have a pair of the smoked ones and don't wanna have to mod it too much to make them fit... I might just go with that option.. .unfortunately I'm still not sure if it's just the wiring or what it'll take to replace the wiring... or what's needed with the hellas as far as wiring
Old 09-03-2002, 11:03 AM   #6
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
The hellas come with a relay, wire and switch but they're only 55 watts (same as stock) so you should be able to just modify the stock harness (i.e. piggy back with vampire taps, or remove the harness all together). The foglight covers may/may not work depending on how you mount the lights. The Kartboy mounts are a good option but make sure you check with Kartboy first to see if the v5/6 covers will fit. The hellas do come with they're own covers though which look pretty good IMHO.
Old 09-03-2002, 03:45 PM   #7
DragonRM
Member#: 14365
well... today I'm gonna swing over to a friend of mine's shop and see about how much it'll be to just replace the wiring since that's probably what it is... I'd rather keep the stock lights for now, if this doesn't work out I'll probably switch though.
Old 09-03-2002, 03:50 PM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
good luck, electrical problems can be a pain in the butt to diagnose. Keep us posted on the results!
Old 09-03-2002, 07:22 PM   #9
Bimmer
Member#: 4116
2002 Impreza TS
Default Re: had a fog light stop working
If you'd burned up the wiring running hotter bulbs, then I'd expect a blown fuse or some sign of melted wiring (highly unlikely, IMHO).
Sounds like a loose connector or a bad ground, I'd look over the wiring myself before taking it in, it's probably something easy. Get yourself a test light and copy of the wiring diagram, if it's only one fog light that's failing then it should be easy to narrow down.
Good luck,
Ben
PS Hella 500's are neat and cheap, CartBoy's mounts are s'posed to be super.
Bimmer is offline   Reply With Quote
Old 09-03-2002, 08:46 PM   #10
DragonRM
Member#: 14365
well... I found a guy who will look at it for free right down the street from me... I've gone through the wiring, changed fuses, bulbs everything I know how to do... just wait and see at this point... I'd prefer to keep the stock lights.. .I've been using xenons that were supposed to be ok with the car and haven't had any probs for over a year... so who knows /shrug
Fog Lights Stopped Working crazycanasian Electrical & Lighting 4 07-11-2009 06:51 PM
Fog lights stopped working go_skins Electrical & Lighting 9 05-20-2009 10:54 AM
fog lights stopped working... do you have the wiring diagram? aveisone Electrical & Lighting 7 02-15-2009 11:16 AM
fog lights stopped working... wrXiconZ Electrical & Lighting 1 09-27-2008 08:18 PM
Fog Lights Stopped Working DanJC18 Electrical & Lighting 12 09-26-2007 03:38 PM
