Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 07-06-2012, 06:25 PM   #1
Chibikishi
Member#: 91757
2013 Limited BRZ
Dark Gray
Default Clunking noise
I've noticed sometimes when I'm shifting into first gear there would be a clunk every so often. It only happens when I'm going into first gear. Has anyone else experienced this? I emailed the dealer asking about it and the guy told me every single BRZ he's driven does that.
Chibikishi is offline   Reply With Quote
Old 07-06-2012, 07:02 PM   #2
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
This has DEFINITELY been discussed here, but I'm having trouble finding the thread. I'm sure it's in this BRZ Forum, though. I'll keep checking.
Old 07-06-2012, 07:08 PM   #3
spaceywilly
Member#: 174268
This was covered in the May techtalk newsletter
BRZ MANUAL TRANSMISSION SOUNDS
You may notice, or customers may question, a "thump" or "thunk" sound intermittently when placing the new six-speed manual transmission into first or reverse while stopped. This is a characteristic of the transmission operation which occurs when any remaining input shaft rotation is brought to a quick stop by gear selection. If enough time is given for the shaft to stop turning on its own, then no thump will occur. No wear or damage is occurring as a result of this action. This sound may be more noticeable as the gear oil warms and gear selection is able to be accomplished with greater speed.
spaceywilly is offline   Reply With Quote
Old 07-06-2012, 07:09 PM   #4
chanomatik
Member#: 159474
SNOSLO
Exactly what I was looking for! Thanks, spacey!
Old 07-06-2012, 07:10 PM   #5
Chibikishi
Member#: 91757
2013 Limited BRZ
Dark Gray
Thanks so much! It's been making me paranoid so thanks for clearing that up for me
Old 07-06-2012, 08:35 PM   #6
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I'm glad Toyota could put some Subaru-style farm equipment noises into the BRZ to remind everyone that it's still a Subaru at heart.
Old 07-09-2012, 05:03 PM   #7
cha6040
Member#: 250984
2013 WRB BRZ
Goodbye Bugeye
Nice. I too was wondering the same about the clunk. Also, with the radio off I noticed the tranny makes a lot of gear noise similar to an STi, even though its a Toyota tranny.
cha6040 is offline   Reply With Quote
Old 07-09-2012, 05:35 PM   #8
Calamity Jesus
Member#: 44501
1984 That's *Sir*
That's probably due to stiff mounts (wild guess).
Old 07-10-2012, 01:50 PM   #9
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Anyone else notice a bit of "groaning" from the rear when taking off from a stop? It's most noticable when the car has been sitting. Not quite a shudder, but I can feel it and barely hear it. LSD maybe? It happens when starting in a straight line as well as turning (like getting out of a parking space).
So far nothing has fallen apart and it sounds like just another one of those quirky Subaru noises.
2point0 is offline   Reply With Quote
Old 08-14-2012, 01:29 AM   #10
BRZ NA
Member#: 328667
has the same problem for the transmission
BRZ NA is offline   Reply With Quote
Old 08-14-2012, 01:31 AM   #11
BRZ NA
Member#: 328667
that's the only issue i have so far and dislike.the clunking noise in first gear!
Old 08-14-2012, 01:33 AM   #12
BRZ NA
Member#: 328667
Is it really a common problem for every BRZ/FRS though?
Old 08-14-2012, 11:47 AM   #13
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Did you read post #3? It's normal.
Old 08-14-2012, 03:43 PM   #14
BRZ NA
Member#: 328667
I know but just can't believe that and I really wanna confirm w owners.
Old 08-14-2012, 04:49 PM   #15
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Well, I'm at over 5000 miles and I can confirm.
I believe Kartboy is working on trans bushings to help.
Push the clutch pedal in for a few sec before shifting into 1st.
Old 08-14-2012, 05:06 PM   #16
spaceywilly
Member#: 174268
I find that leaving the shifter in gear when coming to a stop helps. this way the output shaft is still connected to the wheels when they stop, so it stops instead of spinning freely which causes the clunk
Old 08-14-2012, 08:44 PM   #17
BRZ NA
Member#: 328667
already thx for the input.
Old 08-14-2012, 09:40 PM   #18
fukamoto
Member#: 13339
2014 SWP WRX Wagon
I have this and it bothers the crap out of me.
fukamoto is offline   Reply With Quote
Old 08-15-2012, 12:10 AM   #19
ABQautoxer
Member#: 198231
2007 Not a Subaru
I hate it but sadly I'm used to it. My Genesis Coupe did it as well.
ABQautoxer is offline   Reply With Quote
Old 08-15-2012, 07:38 AM   #20
milenko11
Member#: 34228
13 BRZ
As long as it's normal and nothing is being damaged I'm fine with it.
milenko11 is offline   Reply With Quote
Old 08-15-2012, 02:56 PM   #21
cha6040
Member#: 250984
2013 WRB BRZ
Goodbye Bugeye
This is correct. I have noticed a couple other noises on mine that bug me, not sure if they are normal or not. My trans makes a medium-loud whirring sound when the car is warmed up and I let off the clutch while in neutral at a stand still. Sounds like a throw out bearing, it started at around 3k miles. Anyone else hearing this?
Old 08-15-2012, 03:03 PM   #22
ABQautoxer
Member#: 198231
2007 Not a Subaru
I don't think I have this but I have 10% the miles you do.
Old 08-15-2012, 03:08 PM   #23
spaceywilly
Member#: 174268
Mine hasn't done that, I'll listen for it. I usually have the radio on so I don't really pick up on these things.
