Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 07-07-2012, 08:23 AM   #1
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Default 2litre piston interchangeability
Hi guys. Does anyone have an idea of which pistons can go into my V2 sti? Specifically, can later model GD sti units (eg 2003 model) go in as direct replacement? Do the rods also have to be changed?
I am lead to believe they are not directly interchangeable as the pin to crown heights are different, but just wanted your views...
Cheers
renhoek is offline   Reply With Quote
Old 07-07-2012, 01:06 PM   #2
seangfy
Member#: 242150
1993 impreza L ej20g
aquafrost blue
I do believe that you cant use later pistons without compression and deck height issues but I could be mistaken
seangfy is online now   Reply With Quote
Old 07-07-2012, 06:13 PM   #3
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Yeah, I am thinking the same. If the pin to crown height is less for the newer pistons, then maybe they run a different length rod to compensate, thereby keeping to original overall lengths for the piston/rod combo.
I've got some GC8 stuff lying around. I will measure. Maybe someone has some GDC (say 2003/4) rods they could measure and post.
I sure like the smaller mass of the later pistons and would like to use them in my V2 rebuild if I can.
Old 07-07-2012, 11:40 PM   #4
pmugabi
Member#: 280926
The newer pistons can be used. You simply need to use the same thickness headgasket as is used in the engine that the piston came from.
Rod lengths are the same for all 2litre engines.
pmugabi is offline   Reply With Quote
Old 07-08-2012, 04:54 AM   #5
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Yes but you cannot use the V2 rods with later GD STI pistons, you will have to use the GD STI rods aswell (although same length).
Marnix is offline   Reply With Quote
Old 07-08-2012, 06:03 AM   #6
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Got it. So GD series pistons can go into GC engine, but have to use GD rods as well.
So if you get aftermarket pistons for the sti, eg CP, it sounds like their GC and GD pistons must be different. Is that right? I got the impression from CP that all their WRX STi pistonsnwerenthe same part number SC7400. Is there a different part number for GD engines? Anyone know?
I am rebuilding one of my V2's and am using thee SC7400's in it, with Manley
14024 rods.
Hey Marnix, while I have your ear, I bought yet another V2 STi engine a few weeks ago. I think it is an RA variant due to the 5th injector.
Anyway, I took a head off it to have a look and the head gasket is one of those 2 layer steel hobbies. Not seen that before. And the lifters are shim under bucket. Just thought I would let you know as I know you're interested in such things.
Cheers guys
Old 07-08-2012, 10:52 AM   #7
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
It doesn't matter what EJ20 piston you use as long as you match gasket thickness to compression height of the piston. Ideally you want to end up with 1.1 mm squish for a high revving engine or even 2.3 mm as per 2001 and on JDM EJ207 STI.
