Old 07-07-2012, 03:04 PM   #1
Jdub.csu
Member#: 283784
2013 EVO X GSR
Default Cobb stage 2 log
Here is the log for my Stage 2 2012 WRX.
Is there anything really troubling here?
https://docs.google.com/spreadsheet/...nBxajdSNWxEUFE
Jdub.csu is offline   Reply With Quote
Old 07-08-2012, 06:41 AM   #2
Jdub.csu
Member#: 283784
2013 EVO X GSR
Anyone?
Old 07-08-2012, 10:22 AM   #3
Cobb Tuning
Member#: 4803
Hi there. A log of general part-throttle driving doesn't tell you a lot. You want to put the car under heavy load to see how it reacts. A good run for this purpose would be a 3rd gear wide open throttle (WOT) run from around 2000 RPM on up (if you can do so safely). Check out our data logging video below.
Bill
Old 07-09-2012, 02:15 PM   #4
werks04
Member#: 201804
2012 Impreza WRX
I just did my 2nd data log on a stage 2 map. Car is an 04 WRX. Im a little confused because the first run I hit 15.5 lbs of boost and had higher MAF obviously... And Im still trying to figure out why under WOT it has a rich and steady AFR of 11.25...
Heres my DL
https://docs.google.com/open?id=0Bzg...XZyT19vcXRMY2s
Download it and open in Excel the Google docs has it completely cut off
werks04 is offline   Reply With Quote
Old 07-09-2012, 02:18 PM   #5
werks04
Member#: 201804
2012 Impreza WRX
Also, Bill what is the correct way to estimate HP and TQ from the data? I used MAF/.83 to get HP... I dont even know where that .83 comes from or if its some constant based on Fuel type and AFR
Old 07-09-2012, 02:43 PM   #6
Cobb Tuning
Member#: 4803
Heres my DL
Can you put up the original .csv file on google docs? I'm not able to download the file directly with my account.
I wouldn't bother in trying to use MAF to estimate HP. At best, you may get a ballpark idea of the potential HP, not what you are actually achieving. You are better off with an actual dyno or even using the road dyno function.
Bill
Old 07-09-2012, 02:45 PM   #7
werks04
Member#: 201804
2012 Impreza WRX
Old 07-09-2012, 02:46 PM   #8
werks04
Member#: 201804
2012 Impreza WRX
I think I just need the High Wastegate Stage 2 Map
Old 07-09-2012, 03:07 PM   #9
Cobb Tuning
Member#: 4803
Says "no preview available" - can you start a new thread at cobbforums.com and attach the actual .csv file there (select "manage attachments")?
Bill
Old 07-09-2012, 03:18 PM   #10
werks04
Member#: 201804
2012 Impreza WRX
Old 07-09-2012, 03:54 PM   #11
Cobb Tuning
Member#: 4803
Hi Randy. I took a look at the logs. Everything looks fine - the one concern I would have is that you are using an intake that is not compatible with our OTS maps. Your fuel trims (A/F Learning 1) look fine, but it may have not have been long enough since the last map reflash/reset cleared them to be populated accurately. I would consider putting the stock intake (or Cobb SF intake on), getting your intake tuned for via a custom tune, or at least verify fueling via a wideband o2 sensor. The stock front o2 sensor is not accurate under any appreciable boost (and is limited to 11.2:1 by ECU on rich side). Once you get that straightened out, you could give the HWG map a try (with additional logging).
Bill
