Old 07-08-2012, 01:50 AM   #1
C-bird6969
Member#: 291672
05 Wrx
Default boost problem
05 wrx with new''er'' moter dropped in this week but turbo from old moter. old turbo worked fine held and pushed boost with no problems on old moter. new''er'' moter runs great but when i start to get into boost it starts bogging down and cuting out. it runs great till i get on it a little bit and try to start building boost. soon as i pass over into boost the car also makes this duck call noise and gets louder the more i throttle. i think its a boost leak the shop that put in the new moter missed. here are some datalogs with this issue
https://docs.google.com/spreadsheet/...ExVU3Zwd283Q2c
https://docs.google.com/spreadsheet/...XhMWGl6aG9HQ3c
C-bird6969 is offline   Reply With Quote
Old 07-08-2012, 10:18 AM   #2
Cobb Tuning
Member#: 4803
If the noise is that obvious on boost, you most certainly have a leak somewhere. Get a pressure or smoke test of the intake tract done and check the uppipe (especially if they re-used the old gaskets). Check the exhaust. I would not do any heavy throttle runs until you get this figured out. And be careful of carbon monoxide poisining if it could be an uppipe or exhaust leak.
Bill
Old 07-08-2012, 11:06 AM   #3
C-bird6969
Member#: 291672
05 Wrx
thanks alot bill your a huge help and im sure everone that has had the pleasure of interacting with you will say the same
