Old 07-08-2012, 12:00 PM   #1
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Default 2012, difficult to shift into 5th
Anyone what have this issue, almost feels like the synchro is really slow or bad, i have no issues with any other gears, just 5th. I only try to shift into 5th above 65mph, and it is really difficult to the point where i either need to force it (which i don't) or just sit and wait for maybe 4-5 seconds and then it will shift, but all not as smoothly as all the other gears.
Anyone else?
Old 07-08-2012, 12:16 PM   #2
dennydp
Member#: 308675
2012 sport premium
Met gray
No problems with mine,how many miles? When did it start?
dennydp is offline   Reply With Quote
Old 07-08-2012, 12:30 PM   #3
Zeeper
Member#: 299286
2015 WRX CVT
I would take it in, this isn't a known issue and you are the first person I've seen with this problem.
I would for the future replace the front differential with Amsoil Severe Gear, because I think it really improved the shifting in my car. But my car can shift into 5th without a problem.
Zeeper is offline   Reply With Quote
Old 07-08-2012, 02:47 PM   #4
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
day 1, almost 1400 miles now. it is better now than when it was brand new, but it is still difficult to get into 5th gear. I will bring it in next time I get a chance which is in about 1 week.
so everyone else, there is not difference shifting in all gears, they feel the same?
Old 07-08-2012, 02:52 PM   #5
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i have it sitting on the shelf, was going to put it in once i hit 3,000 miles when i do the differentials.
but i will see what my dealer says first
Old 07-08-2012, 04:22 PM   #6
Zeeper
Member#: 299286
2015 WRX CVT
Yes, have them check it because that is not normal. FYI the front differential is the transmission also, for the 5 speed.
Old 07-08-2012, 07:31 PM   #7
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
After driving today, i guess i wasn't quite remembering exactly how it is. What i described is what it was like when i first got the car, now it is just a little harder to get into gear, don't really have to wait at all, nothing grinds or makes bad noises, just seems like the shift gate has more resistance than the other gears. 1,2,3,4 feel about the same. 5 is just a little more resistance than the others.
Maybe it is because the other gears are used more frequently?
Old 07-08-2012, 08:17 PM   #8
Zeeper
Member#: 299286
2015 WRX CVT
Maybe, if you are concerned bring it to the dealer and have them tell you it is normal, then there is a record if 5th gear craps out.
Old 07-08-2012, 08:27 PM   #9
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
My 5th takes a little muscle but i thought it was just because the angle of the shift and how far away it was from me.
auskip07 is offline   Reply With Quote
Old 07-08-2012, 11:17 PM   #10
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
that could be it. sounds like you experience the same thing i do. for now i'm not going to worry about it.
Old 07-09-2012, 05:23 PM   #11
RoyB
Member#: 316190
All gears go fine for me except Reverse. I have a hell of a time getting it in and sometimes have to coast back or forward a bit to get it in.
RoyB is offline   Reply With Quote
Old 07-09-2012, 06:17 PM   #12
Obsidian.Stephen
Member#: 315640
2012 Impreza 2.0i 5d
Obsidian Black Pearl
Why are you only using 5th above 65mph? You can use 5th above ~40mph with no ill effects and better fuel economy to boot. Obviously if you're accelerating that's a different story but cruising around town you're missing out if you don't use 5th gear.
Obsidian.Stephen is offline   Reply With Quote
Old 07-09-2012, 10:45 PM   #13
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
in my experience so far i have seen better economy in the power band rather than when lugging on the engine. plus 90-95% of my driving is highway
Old 07-09-2012, 10:58 PM   #14
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
the economy gauge likes 3rd or 4th around town more than 5th
Old 07-10-2012, 07:14 AM   #15
Zeeper
Member#: 299286
2015 WRX CVT
Sure, because higher rpm's use less gas???
If you are driving faster than 45mph, 5th gear will not lug the engine, it will reduce rpm's, and it will save gas -- but it's your car, do what you think is awesome.
Old 07-10-2012, 07:58 AM   #16
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Engine load is the biggest factor in gas consumption. 5th gear at 45% load is less fuel efficient than 4th at 20%. Of course the higher the RPM the less fuel efficient but at 3k rpm its pretty darn efficient.
Cars have 3d maps that provide tables for RPM/Load=Fuel Ratio.
Old 07-10-2012, 08:05 AM   #17
RoyB
Member#: 316190
its easy to test this by putting it into 5th at 60 and smashing the gas pedal. The ECO gauge drops, but rpms aren't going up. Engine load is huge though. I always wondered was was more efficient when cruising 45 myself. Usually I put it into 5th because the roads are pretty flat here and it doesn't seem to be lugging the motor. I am going to compare 4th on this tank and see if I can tell a difference.
Old 07-11-2012, 12:00 AM   #18
Obsidian.Stephen
Member#: 315640
From my testing anything about 1.5K RPMs won't lug the engine. This doesn't mean that you don't want to downshift for accelerating but if you are keeping a steady speed (around 40-45+) then 5th gear will give you better fuel economy (the cars instant-MPG readout supports this also).
Old 07-11-2012, 01:14 AM   #19
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Most of the speed limits around here are 25-40 on city streets, with majority being 25-30. Hardly well ever get a chance to use 5th in town
Old 07-19-2012, 07:46 PM   #20
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
finally figured out my problem. on our Jetta you can just kinda make a diagonal movement from center to fifth gear no issues. that doesn't work on the Impreza, if i move over then straight forward it goes into 5th gear quickly and easily, so it was just user error :/
in the 1750 miles on my car, most are 80-100 mile trips, so I haven't actually driven my car more than maybe 25 times.
Old 07-19-2012, 08:06 PM   #21
subypete
Member#: 324361
2012 Impreza Sport
ICM 5MT
I think shifting becomes smoother after more times shifting around on the stick. I remember it was rough going from 2nd to 3rd gear when I first got the car but now it is smooth
1100 miles so far.
subypete is online now   Reply With Quote
Old 07-20-2012, 08:27 AM   #22
punknamedjimmy
Member#: 107329
I actually have this problem too on my 2012 (about 2k miles). Usually just coming off the clutch and reclutching will let me go in. I talked to the dealer about it briefly and they told me to put it into 2nd first and then go to reverse. The purpose being that it 'resynchs the synchros'.
To be honest I am not super pleased by the answer. This is a problem I have with my miata that has 183k on the tranny and should not be an issue on a brand new car.
I am taking it in next week, hoping that they will at least replace the fluid and see if that helps.
punknamedjimmy is offline   Reply With Quote
Old 07-20-2012, 08:50 AM   #23
bottles
Member#: 311522
2012 WRX
Icy Silver Metallic
I had this issue once I first got my WRX, it went away afther about 5000 miles. It was more prevalent when shifting for 3rd to 4th, because sometimes if I wasnt dead on it would pull 2nd. YIKES!!!
bottles is offline   Reply With Quote
Old 07-20-2012, 08:51 AM   #24
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
It is an unsynchronized gear so double clutching helps or using 2nd. I find reverse easiest to get into when I am at high idle right after startup which makes sense.
Afaik it is normal for all these 5sp and if you think it is fluid which it is not, put in something other than factory fill
Old 07-20-2012, 02:19 PM   #25
An owned guy
Member#: 313318
2012 Impreza
Deep Cherry Pearl
Yeah i have the same thing and it dosent really bother me that's it annoying, it bothers me cause it always seems to happen when I'm in the middle of the road backing into something or turning around. So I have a mini heart attack that I'm not gonna be able to get it in and go before a car comes.
An owned guy is offline   Reply With Quote
