Old 07-08-2012, 12:47 PM   #1
DerekDaniel
Member#: 254088
2008 Legacy GT
Default Datalogs need reviewed for 08 Leg Gt stage one ACN 91 map
Hello I just recently flashed my 08 legacy GT auto completely stock. I started with the normal 91 map but was getting some really high numbers on fine knock. Cobb told me to switch to the ACN version since I live in Kansas and it may be the gas. So i re-flashed and took some logs. The fine knock has lessoned but it seems as if some parameters are getting worse with each log can some one please take a look I have provided links to logs for the first three days of Wot pulls. I have noticed some fine knock learning that is slightly high and consistent in the 4500RPM range to 6000 RPM range. Is it still learning possibly? Also the Knock sum keeps going up so does that mean it is still learning it or something else?
first log is 6 July
https://docs.google.com/spreadsheet/...01SMjVjMkdsN1E
2nd log 7 July
https://docs.google.com/spreadsheet/...HZnbjRuUnNQLUE
3rd log 8 July
https://docs.google.com/spreadsheet/...kNEbXYxRm9aLWc
4th log 8 July
https://docs.google.com/spreadsheet/...nNuU3l3M1pYY2c
I appreciate any insight as to what my car is doing and what route should I take.
DerekDaniel is offline   Reply With Quote
Old 07-08-2012, 01:10 PM   #2
DerekDaniel
Member#: 254088
2008 Legacy GT
Default Data logs from first map 91 ATv 301
Here are the two data logs I took when I had the 91 ATv 301 stage one map flashed. As you can see there was high fine knock learning and this is why I was recommended to switch to the ACN version.
Was this the right decision to switch? can anyone look at these and compare them to the ACN versions and let me know which map I should be running? or any issues in my logs? Thank you I greatly appreciate any assistance. Was there cause for concern in these logs? I also noticed there was no knock correction going on with this map but with the ACN map there is alot.
link to first log with 91 ATv map sport mode with high fine knock
https://docs.google.com/spreadsheet/...EptVnQ1S0NDTUE
link to second log with 91 ATv map in sport# mode also high fine knock
https://docs.google.com/spreadsheet/...E1nWmtYaG1PQVE
Old 07-08-2012, 07:57 PM   #3
Cobb Tuning
Member#: 4803
Hi - I responded to your post over at the cobb forums.
Bill
Old 07-09-2012, 10:59 AM   #4
DerekDaniel
Member#: 254088
2008 Legacy GT
Bill
Yep Thanks I posted this prior to reading that. I will monitor those parameters here soon.
