Old 07-09-2012, 03:43 PM   #1
jhornik
Member#: 243342
Default 37.01 PSI...is this possible?
Hey all, here is a datalog I just took on my 2011 WRX Cobb Stg 1 93 oct w/AEM intake. Line 26 showing 37.01 PSI can this be correct or am I reading it wrong, and does everything else look okay? As far as I can tell everything else looks good but I'm no Pro. Thx
https://docs.google.com/spreadsheet/...0TkQzZ1E#gid=0
jhornik is offline   Reply With Quote
Old 07-09-2012, 04:00 PM   #2
Cobb Tuning
Member#: 4803
You'll need to change the permissions to public in order for anyone to view it.
Bill
Old 07-09-2012, 04:12 PM   #3
jhornik
Member#: 243342
Old 07-09-2012, 07:07 PM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
is it repeatable? Do you have a boost gauge? I would lean towards possibly having a bad MAP sensor
Black94Snake is offline   Reply With Quote
Old 07-09-2012, 11:09 PM   #5
Cobb Tuning
Member#: 4803
Could be one of two things - the ECU sending bad data to logger (happens occasionally, but should be rare) or an issue with the MAP sensor. Hard to tell one or the other as it occurred in the middle of a shift (so we can't see if the ECU reacted to it or not). It is also possible not to hit the boost limit fuel cut if this inaccurate spike (say if from MAP sensor) is very brief (boost has to exceed the current boost limit for a short period of time for it be activated).
I would keep logging and see if it happens again. If it does, then likely there's some issue with the MAP sensor. Has the sensor been touched (due to repair or otherwise) on this car or anything in the vicinity?
Bill
Old 07-10-2012, 09:06 AM   #6
jhornik
Member#: 243342
I'm thinking it had to be an error, I've done several more runs and have not been able to reproduce it. Thx
Old 07-10-2012, 02:10 PM   #7
jhornik
Member#: 243342
Well maybe I thought too soon. Got another reading today of 38.07. In regards to the MAF sensor, if that is the problem, what should I do to correct it? Should I just make sure it's on tight or clean it or what? I did just recently install the AEM CAI so that could be it. I'm not getting any CEL's or anything though for over boost.
Old 07-10-2012, 02:46 PM   #8
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
MAP SENSOR
not MAF.
Old 07-10-2012, 02:57 PM   #9
jhornik
Member#: 243342
Originally Posted by Black94Snake View Post
MAP SENSOR
not MAF.
thanks for the correction but doesn't help me much.....that being said any further action I should take?
Old 07-10-2012, 03:09 PM   #10
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Maybe you should re-read your own thread and address the questions which have been posed.
I asked for a reason. Do you SEE a spike?
Bill
if you keep seeing the bad data, but don't see it reflected on a gauge, maybe you should remove your hat rack from your fart box and replace your MAP sensor.
Old 07-10-2012, 03:12 PM   #11
liltoua
Member#: 206802
1998 2.5rs
37 PSI is only possible on EVO's =)
liltoua is offline   Reply With Quote
Old 07-10-2012, 03:15 PM   #12
jhornik
Member#: 243342
It is repeatable per the data log but I do not have a boost gauge.....and I'll make sure to remove that hat rack. Anyway what are the consequences if I do not replace the MAP?
Old 07-10-2012, 03:24 PM   #13
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
fyi, the stock map sensor isn't capable of reading boost this high. so my guess would be an error in the data. highest reading the stock map sensor can output is about 25psi.
amalgrover is offline   Reply With Quote
Old 07-10-2012, 03:28 PM   #14
amalgrover
Member#: 183480
2009 Forester XT
are you sure you were logging manifold relative pressure not manifold absolute pressure
Old 07-10-2012, 03:50 PM   #15
jhornik
Member#: 243342
It's PSI I'm reading on the data log
Old 07-10-2012, 04:00 PM   #16
Cobb Tuning
Member#: 4803
We are certainly not dealing with an actual boost spike here - no way you are going see boost that high on the stock turbo regardless let alone a 20+ psi spike in half a second.
amalgrover has a good point - even if the sensor was defective and pegged at 5 volts, the most you would see with this car and the stock MAP sensor/calibration would be about 27 psig at sea level. Bad logging data makes the most sense here. But, I would add barometric pressure and manifold absolute pressure to your logs. "Boost" monitor in the logs is in relative pressure, but it is calculated by ECU as (manifold abs. pressure - baro. pressure). So, if there was an issue with the baro. pressure reading, it would impact the boost monitor. But, the numbers don't really jive with 37 psig (even if baro pressure was reading at 0 psi, you would have to hit 22 psig, which doesn't make sense in your first log). The calculated load monitor also shows a value over 7.5 g/rev in that line, but this is not reflected in the airflow value. That makes me think these two monitors (boost and calculated load) had bad data in the ECU's response. Can you post the log with the second example of the issue?
Bill
Old 07-10-2012, 04:41 PM   #17
jhornik
Member#: 243342
Here is the link with the new log.
https://docs.google.com/spreadsheet/...Ud4SmtEWmoyN0E
Also, should I be concerned with the knock that is high and it's while it's under load? I've read where the flat foot shift can throw that off sometime but not sure that's the problem here.
Thx
Old 07-11-2012, 09:49 AM   #18
Cobb Tuning
Member#: 4803
Thx
Definitely the logging data getting corrupted somewhere along the line. Has this car had any repairs at all? Been in an accident? I was thinking maybe you had a loose ground since it happens in-between shifts.
What you are seeing as far as the feedback knock correction is known as throttle mash/shift knock as is generally noise. Keep in mind the ECU holds the correction and "slowly" ramps it back to zero, so the only perceived event(s) is when feedback correction drops as compared to the previous line. This kind of false knock can occur even when not using flat-foot shift.
Bill
Old 07-11-2012, 10:05 AM   #19
jhornik
Member#: 243342
Thanks Bill. As far as accidents or repairs go, no nothing has been done. I am the only owner of the vehicle and it has never been in an accident or needed any major repair. Really the only work that has been done on the car is general maint such as oil changes. I also installed the AEM CAI as mentioned but that's it. You think I should reset the ECU and see if I continue getting the same results?
Old 07-11-2012, 10:14 AM   #20
Cobb Tuning
Member#: 4803
I don't think resetting the ECU will matter, but it woudn't hurt. Do more data logging and if it happens fairly frequently, then I would give our tech support people a call: 866-922-3059. They may have additional troubleshooting steps to work through.
Bill
Old 07-11-2012, 10:21 AM   #21
jhornik
Member#: 243342
Great, will do Bill....thanks again.
Old 07-11-2012, 10:33 AM   #22
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
This same thing happened to me. Resetting the ECU didn't fix anything. I reflashed the map (which also resets the ECU) and it did it again. Reflashed for a second time and everything went back to normal and I haven't seen this happen in 2-3 months.
I think it's just a weird fluke. Could've been a bad/semi-corrupt flash image, who knows.
wgr73 is offline   Reply With Quote
Old 07-11-2012, 04:07 PM   #23
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I've seen this issue on mostly 08 and newer cars. It also will do it on the romraider logger so I'm sure its a sensor issue or ecu issue. Its never more than one line of data. Happens when logging a wideband sensor t times also.
fastblueufo is offline   Reply With Quote
