Old 07-09-2012, 05:09 PM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default 6k ecu on 91 octane?
Basically can I run the following setup on 91
6k ECU
95 EJ20G
95 td05-16g
oem boost control solenoid (stock 13.64 psi)
walbro 255 lp/h
3" catless turboback
wrx coilpacks w/ BKR7E @ .028 gap.
Relevant telemetry (Wideband/Oil PSI/Oil Temp/Boost)
I've done a search here were some said it might be dangerous, but others did not seem to share the same concerns.
JDMFLCL is offline   Reply With Quote
Old 07-09-2012, 06:05 PM   #2
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Safe to go for sunday drives? Probably. Safe to thrash it at the track? Probably not a good idea.
94 octane is a much better safer option.
It's much easier and safer for people here to tell you that its going to go badly and then be wrong then it is for people to tell you its just fine and be wrong.
You dont need anyone's permission to fill your tank with borderline insufficient octane fuel. But safely driving with insufficient octane generally requires lower ambient air temp. This leads to a lower intake air charge temp and more effect performance from your inter-cooler. A lower engine temp couldn't hurt either. I'm sure you already know this.
You can go fmic, which if done well can reduce your intake air charge temp quite nicely as such its typically the first step people take before safely turning up boost. More boost increases temp so you could also get an MBC and limit the boost to say 10psi to prevent potential detonation . Up to you.
Really its a matter of if you understand what higher octane fuel means and if you understand what causes detonation. High octane fuel doesnt contain more power. More octane means more controlled combustion through less volatility.
You can get the same control through lowering temperatures.
TommyAtomic is offline   Reply With Quote
Old 07-09-2012, 07:08 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes it's ok. I ran that exact combo when I first did my swap. I had to travel out of state a few times with it where I could only get 91. I though it would drop the IAM, so I checked it on the road, but it didn't.
Old 07-09-2012, 07:12 PM   #4
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I already have a fmic. Will a fmic+VTA work with non oem boost control? I have a MBC+CX FMIC. Say MBC @ 13.64 PSI, CX FMIC w/ VTA bov and plugged intake hole. Or do the jdm ecus not like VTA bovs?
I do not have access to 94. I'm trading back from a PFC setup and potentially selling the car.
Old 07-09-2012, 07:26 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
If you have a fmic you want to use a mbc. The bov is fine too.
Old 07-09-2012, 07:30 PM   #6
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I see. So the 6k ecu will run fine with the above setup just like the z4.
Old 07-09-2012, 07:50 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
They aren't much different really.
Old 07-09-2012, 10:55 PM   #8
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I see. I ran the z4 ecu on 91 octane gas for 2 years with no problems. Would you say I could do a trackday maybe with boost turned down to 12?
Old 07-10-2012, 12:15 AM   #9
blessthekellen
Member#: 273859
MY98
WRX
Answer is yes you can.
Highly recommend Robs tune however. Really wakes up the EJ20G on 91 octane.
blessthekellen is offline   Reply With Quote
Old 07-10-2012, 12:35 AM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
No idea, I don't do those.
Old 07-10-2012, 01:27 AM   #11
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I see
Old 07-10-2012, 01:39 AM   #12
eg33GC
Member#: 206851
56 Belair
Pro Street
there is low risk, the ecu drops iam quickly
eg33GC is offline   Reply With Quote
Old 07-10-2012, 01:51 AM   #13
pmugabi
Member#: 280926
Yes, there is low risk if the IAM never gets to zero, the ECU is very good at managing det.
When I first logged IAM, I was shocked to find it pegged at zero. To me that explained the number of engines I had gone through in the previous 2 years (at least 5). I've not had a single failure since I redid the tune, so avoiding det is extremely important.
Maybe the OP should invest in a data logging cable and check that the IAM is always above 8, that way there is a margin of safety.
pmugabi is offline   Reply With Quote
Old 07-10-2012, 11:09 AM   #14
JDMFLCL
Member#: 180513
Baby Baby C'mon!
jake can you pm me please? also which type of datalogging software do you guys recommend? I'm used to using a PFC commander where I can view everything.
Is the 6k ecu really too aggressive for 91 when driven in anger?
Old 07-10-2012, 01:11 PM   #15
pmugabi
Member#: 280926
Evoscan works best for me. There are a couple of free loggers like the Ecutune one but I've never got them to work.
Old 07-10-2012, 01:42 PM   #16
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I see. If i bought evoscan, is there anything I could do aside from letting off to ensure the car running safely on 91 octane?
Old 07-10-2012, 01:49 PM   #17
69subaru360
Member#: 159682
1995 WRX
2015 F150
I've run the 6K hard on the street on 91 a few times during road trips when I couldn't get 93 and the IAM stays at 16, but I don't know about a track day, I don't have experience with that.
Old 07-10-2012, 01:59 PM   #18
JDMFLCL
Member#: 180513
Baby Baby C'mon!
I see. What would power output be around? 200-210whp?
Old 07-13-2012, 12:51 PM   #19
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Reporting back. Car ran absolutely flawlessly. I even romped on it once
