Old 07-09-2012, 09:28 PM   #1
Just1More
Member#: 319078
2005 STi
Default Did i lock out my ECU?
Using ECUflash and Tactrix cable only, disabled my TGV delete CEL's, etc.. Today i went to read the map and as it was loading to my laptop, i set it down and almost closed the lid accidentally. Enough that it went into sleep mode. Now all icons(read from ECU, write to ECU, Test write, etc..) are grey and i can't click any. I've done the correct process and still nothing. I Uninstalled ECUflash, reinstalled and tried again with no luck. Any ideas? I will have to wait until the weekend before i can have someone with their own laptop and Tactrix cable to see if they can connect. Thanks for any tips you can offer.
Mark
Just1More is offline   Reply With Quote
Old 07-09-2012, 11:09 PM   #2
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
If your just reading the rom then your fine... If you were writing when it failed then thats a different story.
Bamofo is offline   Reply With Quote
Old 07-11-2012, 01:25 PM   #3
quazimoto
Member#: 70395
This. And you wouldn't be locked out. More like you bricked the ECU
quazimoto is offline   Reply With Quote
Old 07-18-2012, 12:51 PM   #4
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
it likely would only have bricked it if he was writing the map and turned the key off at any time before it was finished.
Uncle Tattoo is offline   Reply With Quote
Old 07-19-2012, 12:26 PM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
op 2.0?
cable's probably bad
Nuke209 is offline   Reply With Quote
