Old 07-09-2012, 11:36 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default 2011 WRX: Blown 5 Speed -> PAR Gears
Update: Switched to a straight cut second gear mid October. More info HERE
Input shaft (with straight cut 1st and 2nd), 2nd gear, and 3rd gear synchro cone from PAR.
Gears assembled into the case. Didn't take any photos of the synchros before install.
Background:
My car is a 2011 WRX with a Blouch 20G XT-R. It is tuned on E85 and made 462WHP / 492WTQ. I have been running the 20G XTR for 8-10k miles. Originally I was at around 22-24psi and making just over 400WHP. My motor blew over the winter so I swapped in a built short block. When I did this I also increased the boost to about 27psi peak (this is the boost level I was at for the dyno results above). Once I got to this point the clutch started slipping, even with the ACT HD pressure plate, ACT full face organic disk, and ACT flywheel. I decided I had no choice but to go with a new clutch. I swapped the disk from the full face disk to an ACT 4 puck sprung disk. I really wanted to avoid this type of setup for the sake of my tranny, but with the other setup slipping, I went with it anyways. Here's more info on the car:
http://forums.nasioc.com/forums/show....php?t=2078765
With the puck clutch setup and the torque I was making, I knew it was only a matter of time before the tranny went out. It lasted through the winter and all was going pretty well. A couple weeks ago I went to the road course. I did a warm up session and everything was going fine. I made it through about half a dozen laps during the first full speed session. During the track day I was not flat foot shifting, or slamming the gears. I did not have any mis-shifts. I just came out of a turn in 3rd gear and when I put the pedal down it just let go completely and the car revved like it was in neutral. It sounded like a tin can full of loose change.
I pulled the tranny drain plug and found a bunch of teeth stuck to it. When the fluid drained out I got a few more. Here are some photos:
I had been researching my options and looking at what was available. I eventually ruled out the 6 speed because of the added cost and complexity of doing the complete swap. I then began looking at built 5 speeds. Unfortunately the 08+ WRX's use a 3.9 final drive, so it's not quite as easy as just swapping in a new tranny. This left me with the option of buying a tranny and having it disassembled and swapped over, or just buying a gearset.
After looking around I decided to go with just a gearset. I would like to thank Andrewtech, PAR, and the gear seller, Joe, and my mechanic, Vandde, for all the help along the way. Andrewtech and PAR were very helpful for someone who was trying to do research. Joe went above and beyond in getting me the parts and answering questions. Vandde and PAR helped out getting everything assembled correctly. Also thanks to Derek and my brother for the help removing (Derek) and installing (my brother) the tranny!
Also, I did read the thread about the PAR input shaft failing with relatively low miles. From what I can tell, that is an isolated indecent. Andrewtech had nothing but good things to say about the PAR 650HP gearset and still recommended it to me over PPG's even after that failure. I am very fortunate to find a set in the condition that I did.
xluben is offline   Reply With Quote
Old 07-09-2012, 11:37 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Now, onto the swap! First, pulled the tranny for the rebuild:
Here are some photos of the stock (broken) gears:
And you can see that there is some wear on 1st gear:
Old 07-09-2012, 11:37 PM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Now, here are the PAR Gears:
The PAR gearset comes with a straight cut 1st gear and helical 2nd-4th. 5th gear is OEM. The ratios are as follows:
Code:
Gear	Stock Ratio	PAR Ratio
1	3.166		3.180
2	1.882		1.850
3	1.296		1.310
4	0.972		0.950
5	0.738		0.738
FD	3.900		3.900
Using those ratios, this calculator gives the approximate vehicle speed by RPM. It is not perfectly accurate, but should give a good estimation on the difference between the gearsets. The difference is quite small. 1st-3rd are within about 1mph of stock and 4th is a few mph's faster.
Stock:
http://www.car-videos.net/tools/spee...B1=Recalculate
PAR:
Code:
Gear	Stock MPH @ 7k	PAR MPH @ 7k
1	40.7		40.6
2	68.5		69.7
3	99.5		98.5
4	132.7		135.8
5	174.8		174.8
I think this is a good match for my powerband. I don't find myself needing the close ratio's of the 6 speed, so my preference was for keeping the longer 5 speed gears. The slightly taller 4th should be plenty for the 1/4 mile unless I make the car considerably faster (stock 4th would also have been OK, but this is more headroom).
Comparison Photos:
The tooth size and profile of the PAR gears is much larger than the OEM gears. They look great. Everything appears to be in excellent condition. The straight cut first gear whines quite a bit (just like reverse). It is quite a head turner in parking lots! I'll have to try and get a video of this soon.
Here it is all cleaned up and assembled. Ready to go back in.
So far, so good. It's only been in for a few days now, but it's all running smoothly. Nice solid whine in first gear, but the rest is pretty stock-like. Overall it is a little noisier, but not much. It drives very nicely and shifts smoothly (like a synchro tranny should). I'm hoping it can hold up to the power, unlike the stock gears!
Old 07-09-2012, 11:38 PM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here is a video from the track when 3rd gear actually failed.
I'll try to get a video with the new gears sometime soon!
Here's a quick video of me running through the gears. You can hear the whine in 1st
Old 07-09-2012, 11:52 PM   #5
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
nice work jerk
so how strong are these?
Celery GT-5 is offline   Reply With Quote
Old 07-09-2012, 11:59 PM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by Celery GT-5 View Post
nice work jerk
Thanks?
They're rated at 650HP. Hopefully they last.
http://www.par-engineering.com/secti...ru&sectionId=2
Old 07-10-2012, 12:01 AM   #7
Celery GT-5
Member#: 98210
2016 Forester XT
CWP
nice, so were you really gonna trade in the car or was it just a trick again?
Old 07-10-2012, 04:53 AM   #8
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
nice xluben.. the par gears look like they can hold some power... teeth look like they are double the size of the factory ones
Gregor91 is offline   Reply With Quote
Old 07-10-2012, 12:07 PM   #9
besthaticouldo
Member#: 279660
damn dude...i love my 5spd, i feel no need for a 6er. so this seems to be a great option i think.
besthaticouldo is offline   Reply With Quote
Old 07-10-2012, 08:11 PM   #10
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Glad to see this monster up and running again.
kyletakahero is offline   Reply With Quote
Old 07-10-2012, 08:16 PM   #11
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
This!
96accord is offline   Reply With Quote
Old 07-10-2012, 08:38 PM   #12
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Trick.
I hope so. The teeth are quite large.
As long as it lasts. I do like the ratios.
Originally Posted by 96accord View Post
This!
Me too.
Old 07-10-2012, 08:44 PM   #13
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
awesome! you must be pretty happy to get her back up and running!
BigRob74 is offline   Reply With Quote
Old 07-10-2012, 08:46 PM   #14
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
If you dont mind me asking how much did you pay for the gearset + all the labor?
WRB19 is offline   Reply With Quote
Old 07-10-2012, 10:44 PM   #15
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Old 07-11-2012, 12:53 AM   #16
kevosti
Member#: 269463
2012 WRX STi Sedan
Why straight cut 1st gear instead of helical?
kevosti is offline   Reply With Quote
Old 07-11-2012, 07:59 AM   #17
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Straight cut 1st gear for minimal thrust loads when launching at full power. This protects the thrust bearings supporting the transmission shafts from the shock loads experienced during hard launches, especially when using puck type and multi-plate/rigid center clutch assemblies.
Old 07-11-2012, 08:23 AM   #18
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Would you be opposed to throwing a Moore Performance 5spd brace on the transmission? I think that ~300 would be well spent to help combat case flex.
abrumlev is offline   Reply With Quote
Old 07-11-2012, 09:22 AM   #19
WRXinpa
Member#: 306708
2012 WRX Hatch SWP
TP Stage 2
+1
I have gotten used to the 5 spd after coming from a 6 spd and wouldn't want to go back. With the power you've got, a 6 spd shouldn't make the car any faster around the track. This is a good alternative to doing a full 6 spd swap. Awesome pictures
WRXinpa is offline   Reply With Quote
Old 07-11-2012, 09:37 AM   #20
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I'm not opposed to it, but the time for doing that is kind of past, lol. I had a hard time convincing myself it would make much of a difference. Hopefully that doesn't come back to bite me...
I would contact Andrewtech and/or your shop for rates. The PAR gearset is around $4500 from Andrewtech. I pulled and installed the tranny myself, so that saved some costs, but if you're having a shop do all the work, then I would just get a quote from them.
Originally Posted by WRXinpa View Post
+1
Yeah, I like the 5 speed gearing. As long as this holds up I will be happy with the setup.
Old 07-11-2012, 01:03 PM   #21
Samurai Jack
Member#: 21145
2002 Enemy of Aku
$399 USD
Samurai Jack is offline   Reply With Quote
Old 07-11-2012, 01:07 PM   #22
MattyTee
Member#: 315355
2014 WRX Ltd 5 Door
CBS
Very cool write up, vids and pics. I've been enjoying your setup vicariously since I will likely never have the cash or balls for that level of modding. Cheers!
MattyTee is offline   Reply With Quote
Old 07-11-2012, 01:27 PM   #23
jprice130
Member#: 288225
2013 FR-S
Oh my goodness....That video of you running thru the gears is proof positive that the PAR gears have found their proper home. Just sick man....congrats!
jprice130 is offline   Reply With Quote
Old 07-11-2012, 02:14 PM   #24
Pearldrummer7
Member#: 277514
2012 WRX & 818R
looks great! those gears should be pretty indestructible, even at 450+ hp.
I thought I recognized this car from somewhere....2011-12 picture thread!
1.850 for 2nd gear....what can you hit in 2nd, then? about 70? the video was a little hard to tell from. The straight cut sounds fantastic!
nevermind:The difference is quite small. 1st-3rd are within about 1mph of stock and 4th is a few mph's faster.
nice work
didn't catch that part.
nicely done!
Pearldrummer7 is offline   Reply With Quote
Old 07-11-2012, 02:45 PM   #25
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I had never worked on a car before this one. Just go for it!
Thanks again! I'm really liking them!
nice work
nicely done!
Yeah, the gearing is very similar. Should be close to 70mph if I rev to 7k. I was only going to about 6.5k in the video.
