Old 01-31-2013, 03:37 PM   #326
skywaffles
Member#: 82470
I am more humble
than you can understand.
Originally Posted by WRXHillClimb View Post
$2800 for FIBERGLASS rear end? Does that even include paint? Holy crap. It looks better, but I'm not sure it looks $2800 better .
Why the outrage at fiberglass? You know the body is made out of it, right?
skywaffles is online now   Reply With Quote
Old 01-31-2013, 04:35 PM   #327
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
The modern vette bodies are made out of SMC, a reinforced plastic.
The bumpers are made out of urethane.. because they're bumpers and aren't supposed to show damage from a 3mph impact.
Fiberglass cracks from very mild impacts.
Fiberglass bumpers almost invariably develop cracks.. even ricers know this.
Old 01-31-2013, 04:51 PM   #328
AWDPilot
Member#: 25058
'15 Legacy 3.6R
10 Subarus...and counting
The car isn't even out yet, I'm sure there will be SMC version in multitudes of designs once the car is on the lot and can be properly prototyped.
Fiberglass molds are a lot easier to change then a injected plastic mold.
AWDPilot is offline   Reply With Quote
Old 01-31-2013, 11:03 PM   #329
53x12
Member#: 206332
Isn't the new C7 using significantly more carbon fiber and composite material than the C6 used?
53x12 is offline   Reply With Quote
Old 01-31-2013, 11:11 PM   #330
Skunkers
Member#: 115480
I had initially heard that the entire outside body was CF, but it seems that was wrong (too good to be true anyway). The Chevy website specifically says the hood and roof are CF, so presumably the rest of the car is something else. I think i read the vents are CF as well. They are also using real CF for the interior trim, anything that looks carbon fiber IS carbon fiber, there is no carbon-look material anywhere in the car.
Skunkers is offline   Reply With Quote
Old 01-31-2013, 11:16 PM   #331
WRXHillClimb
Member#: 206907
2014 EvoX GSR
The old ones maybe, new ones (as stated) don't. It's not the fact that it's made out of fiberglass either, it's the price for such a crappy material. I could see maybe $1k for that, which is still loads more expensive than your avg ebay ricer bumper, but not a penny more. They basically already had the mold (the current rear end) and just had to adapt it. If it was CF, 2800 is fine...
WRXHillClimb is offline   Reply With Quote
Old 01-31-2013, 11:28 PM   #332
53x12
Member#: 206332
Yeah. This is the best info I have found so far:
C7ís use of materials includes a standard carbon-fiber hood and roof panel, supplied by Plasan Carbon Compositesí new Walker, MI, plant. Plasan has innovative manufacturing processes that shatter previous autoclave-type processing times, getting per-part processing down to 17-min machine cycles. For more detail, read this AEI article.
The unique balsa-wood-sandwich floor construction of the C6 Corvette has been superseded on C7 by a new carbon nano-composite floor pan that is lighter while maintaining strength and stiffness, said Chief Engineer Tadge Juechter.
C7ís front fenders, doors, rear quarter panels, and the rear hatch panel are made with lighter-density sheet molding compound (SMC) than the previous generation. The door outer panel measures 1.2 mm (0.047 in) thick and the inner panel 0.8 mm (0.031 in). Combined, the body materials and their design/engineering save approximately 37 lb (17 kg) vs. the C6 body structure.
http://www.sae.org/mags/aei/11722
Looks like carbon fiber, carbon composite and SMC make up the stock C7 body material. Along with aluminum for chassis obviously.
Old 01-31-2013, 11:48 PM   #333
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Aw no more jokes about balsa wood.
OrbitalEllipses is offline   Reply With Quote
Old 02-06-2013, 11:50 AM   #334
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
No handle to open doors on the inside. Thumb button as you put your hand on the door. Grab handle, push button with thumb, push door open. Not sure how I feel about that. What happens if the battery dies? I do like the push-button start, but that's not "new". It's just different from the last Corvette I've driven (C5). I like the new seats. Much better bolstering. Driver's seat and surroundings remind me of a cockpit. I think the height of the center tunnel for the drive shaft has a lot to do with it, but it gives me a warm, fuzzy, happy feeling.
Scooby921 is offline   Reply With Quote
Old 02-06-2013, 02:33 PM   #335
skywaffles
Member#: 82470
I am more humble
I imagine the doors will work the same as the C6, which has been fine for a decade. If the battery dies there's a key in the fob that you insert into a slot above the license plate. This opens the hatch/rear compartment. Inside you will find two cables on the driver's side. One opens the driver's door, the other opens the gas door.
Old 02-06-2013, 03:00 PM   #336
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Wow. Talk about engineering.
Old 02-06-2013, 04:16 PM   #337
delongedoug
Member#: 124113
and beyond!
How can you get to the license plate if you can't get out of the car?
delongedoug is offline   Reply With Quote
Old 02-06-2013, 04:30 PM   #338
AWDPilot
Member#: 25058
'15 Legacy 3.6R
There's a manual release handle for the door from the inside as well down on the floorboard where most trunk release handles would be.
Old 02-06-2013, 04:36 PM   #339
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
Roll down the power windows...duh.
mhoward1 is offline   Reply With Quote
Old 02-06-2013, 04:40 PM   #340
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
here you go...from the Manual:
If power to the vehicle or the keyless access transmitter is lost, there are two ways to open the door. From inside the vehicle, use the door release handle located on the floor next to each seat. Pull the handle up to unlock and unlatch the door. From outside the vehicle, use the door release tab located on the carpet inside the trunk on the driver’s side of the vehicle. Pull the tab to unlock and unlatch the driver’s door. See Hatch/Trunk on page 2-14 for information on opening the trunk during a loss of power.
Old 02-06-2013, 05:01 PM   #341
delongedoug
Member#: 124113
and beyond!
I think the point is you shouldn't need a manual to get out of a car. Creating inconvenience while adding nothing is stupid design.
Old 02-06-2013, 05:43 PM   #342
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Agreed. You aren't saving any weight by adding a switch AND still maintaining a manual release. IMO a well shaped door handle has a better appearance than a ****ing button in the middle of the door that detracts from the otherwise clean and smooth appearance.
Old 02-06-2013, 08:06 PM   #343
skywaffles
Member#: 82470
I am more humble
There isn't a button on the door there's a cutout at the edge of the door that pops it.
Old 02-06-2013, 08:10 PM   #344
bestfromnw
Member#: 281835
2008 STI
1990 mk2 GLi vdub
that doesnt look too bad anyway
bestfromnw is offline   Reply With Quote
Old 02-06-2013, 08:11 PM   #345
delongedoug
Member#: 124113
and beyond!
How ****ing complicated do you need to make a door handle!? What a valuable gimmick.
Old 02-06-2013, 11:46 PM   #346
hi5.0
Member#: 340456
2013 Impreza
Wonderful. More crap in a car that's waiting to go wrong. My cousin had that kind of fun when his C6 crapped out on him in that manner. Probably part of the reason he traded it in (though he'll never want to admit it).
hi5.0 is offline   Reply With Quote
Old 02-07-2013, 11:13 AM   #347
Sid03SVT
Member#: 183032
2006 Betty
If you don't like gimickie crap, or want to at least minimize it, buy a lotus. I imagine MOST people that buy these cars enjoy the gimmickie crap because it's "cool" "futuristic" "other buzz word".
Screw it, I'm building my own car from the ground up, with no R&D money other than what i have in the change jar on my desk in my home office.
crank windows, manual locks, no AC, no TC, no TPMS, none of that.
Sid03SVT is offline   Reply With Quote
Old 02-07-2013, 12:22 PM   #348
delongedoug
Member#: 124113
and beyond!
Yep, sounds like both my cars except for the manual windows and locks. Both of which actually offer a valuable and easy to use function.
Old 02-07-2013, 12:31 PM   #349
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I know there is a cutout on the exterior. There is a little pressure switch in there like you commonly find for a trunk/hatch release. That is all fine and wonderful. I was complaining about the little button on the interior door handle. It seems well placed for where your thumb will be when your hand is on the door handle to push it open, but it's still a button in the middle of an otherwise smooth, flowing surface.
Old 02-11-2013, 11:53 AM   #350
warpath
Member#: 84622
2016 TR Golf R
1992 MKIII Supra
Default Chevy shows much-improved 2014 Corvette interior in new video
Here it is.
Autoblog: http://www.autoblog.com/2013/02/11/c...-in-new-video/
If you want a closer look at what went into designing and building the interior for the 2014 Chevrolet Corvette, we've got just the thing. General Motors has released a new video detailing the cabin's evolution from conception to execution, complete with commentary from Ryan Vaughn, performance car interior design manager with Chevrolet. The quick clip details how manufacturing, engineering and design within General Motors worked together from the first sketches to ensure no compromises had to be made later down the line. How novel.
With plenty of hides traced with contrast stitching and available real carbon fiber trim, the cabin looks to be a few hundred miles ahead of the C6. Given how readily critics derided the previous generation for its cabin, the C7 should make writers work a little harder to find something to complain about. Check out the video below for yourself.
warpath is offline   Reply With Quote
