Old 07-10-2012, 01:13 PM   #1
etidatreyu
Member#: 285495
2004 WRX
Default Car won't start when hot
Hey guys, I have a 94 Impreza L with a V2 STI swap. I recently got it off another member and about a month ago it started giving me an issue where the car will start and run perfectly fine, and then if I turn the car off and try to start it 10 minutes later it wont start, but if I wait about an hour it'll start up no problem. Any ideas?
etidatreyu is offline   Reply With Quote
Old 07-10-2012, 01:32 PM   #2
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Cam and/or crank sensor. Check the wiring at the sensor plugs first. If they look ok, then replace the sensors.
-Rob
rob is offline   Reply With Quote
Old 07-10-2012, 01:45 PM   #3
etidatreyu
Member#: 285495
2004 WRX
Thanks man, I'll check it out
Old 07-11-2012, 02:22 PM   #4
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Could you explain "wont start" . Does it crank and not turn over or does it not crank or what? I had a hot start issue when I first got my jdm wrx years ago. I think I fixed it with a new coolant temp sensor and a new fuel pump.
TommyAtomic is offline   Reply With Quote
Old 07-11-2012, 06:40 PM   #5
etidatreyu
Member#: 285495
2004 WRX
It will turn over, but it won't actually start. Was that your issue as well?
Old 09-09-2012, 02:33 PM   #6
ColesSTi
Member#: 99205
2005 Impreza WRX
My car is having the same problem I have a 2005 wrx with a 2.5 big valve head long
block from element tuning with hydra em Phil cant figure out whats wrong I am thinking
about taking the car to someone else I am located in MD. I need this problem fixed I
have too much money invested in my car for this problem. Phil once thought it was
the engine not seeing enough fuel so he maxed out the signal going to the injectors.
Cole
ColesSTi is offline   Reply With Quote
Old 09-09-2012, 06:09 PM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Oh oh oh. Coolant temperature sensor malfunction can cause hot start problems.
i_c_the_light is offline   Reply With Quote
Old 09-09-2012, 10:06 PM   #8
ColesSTi
Member#: 99205
2005 Impreza WRX
That's possible do I have to buy that sensor at subaru?
Old 09-09-2012, 10:33 PM   #9
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
That was my issue. After replacing the issue was resolved.
beaviscih is offline   Reply With Quote
Old 09-10-2012, 12:39 AM   #10
Francois_
Member#: 284101
2004 STI
world rally blue
I have a similar issue with my built 2.0l. Cold starts are fine. Once I shut the car off (getting gas or something) and start it back up, it'll want to die out but if I give it just a bit of gas, it's fine and idles perfectly normal.
Francois_ is offline   Reply With Quote
Old 09-10-2012, 05:57 PM   #11
ColesSTi
Member#: 99205
2005 Impreza WRX
I am going to try to check the coolant sensor with a muti-meter and check the Ohms Does anyone know what the sensor should read normally?
Old 09-10-2012, 06:01 PM   #12
eg33GC
Member#: 206851
56 Belair
Pro Street
my 94 RA engine I just bought would almost not start once up to temp. The ect/iacv/crank/cam sensors were all clean or brand new.
Then of course it spun a bearing after 80miles so I have no idea what it was..
After doing some digging into the ecu rom, I think it is our ****ty fuel enrichment/cranking fuel/temp based enrichment that does this. If I have some spare time I will try to test a rom once I have a G powered car.
eg33GC is offline   Reply With Quote
Old 09-12-2012, 11:32 PM   #13
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
I had this problem for a long time. it was the cam sensor. It takes only 1 minute to change.
Tizzle is offline   Reply With Quote
