Old 07-10-2012, 07:17 PM   #1
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Default Stock USB with Aftermarket Radio - NO Cutting
Looking to use your armrest USB port with an aftermarket radio and not in the mood for cutting the stock harness? I just did the quick mod to my car and it works great.
Here is what is needed:
This is a link to buy the connector that fits the end of the stock USB plug harness: http://www.mouser.com/ProductDetail/...u3jONiJIhfY%3D
A perfect fit:
The part came in ~4 days and didnt cost much considering.
The only other "part" YOU will need (I needed extra parts to map out the wiring) is an old USB cable you dont mind cutting.
You will also want a soldering iron, electrical tape, and a prying tool to remove the trim around the radio.
All you have to do is solder the following (the Hirose connector is labeled 1-4 and the outside is ground.
Connect the end of an old USB cable you cut to the following pins:
1. Black
2. Red
3. Green
4. White
Finally, attach the wire that was wrapping the colored wires to the outside of the Hirose connector.. thats it, plug and play!
To make this I cut a second USB and used a continuity tester to map out which pin on the Hirose harness goes to which USB pin. (This step you dont need to do unless you care to double check my work)
Testing pins: (Again not unless you want to double check my pinout)
Chopping an old unused USB cable to solder to the harness:
Color coded:
My terrible solder job:
Wrapping in electrical tape - careful not to touch pins together! or disconnect anything!
Testing one last time to ensure connections are solid
Worked perfect - You can make this as professional as you want with better soldering or maybe there is a clip that can attach to those pins? I would recommend buying 2 hirose connectors for this job because the pins are brittle. I had 2 pins break, but it actually made it easier to solder without them in the way.
MtnXfreeride is offline   Reply With Quote
Old 07-10-2012, 10:42 PM   #2
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
Thanks for the info and pics! I'll be saving this one for the future...haven't even received my 2012 yet, haha
Psyk is offline   Reply With Quote
Old 07-17-2012, 08:13 PM   #3
noblepete
Member#: 320154
Thank you for the tip. I've ordered the connector you mentioned, which came in today, and I will be attempting my install this weekend, weather/work permitting.
noblepete is offline   Reply With Quote
Old 07-19-2012, 05:12 PM   #4
Joker_927
Member#: 267865
2020 WishIHadMySubby
Imaginary Blue
Really cool! Thanks!
Joker_927 is offline   Reply With Quote
Old 07-19-2012, 11:38 PM   #5
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
the part does come decently quick.. and you can prep the part so all you have to do in the car is pop off the dash trim and find the plugs to plug in.
Old 08-20-2012, 11:34 AM   #6
Spincity9080
Member#: 329282
2013 wrx sti
plasma blue pearl
This is Awsome.... Thanks I as well will be doing this
Spincity9080 is offline   Reply With Quote
Old 08-22-2012, 01:35 AM   #7
gunz4me
Member#: 305130
2013 GTI
Candy White
Thanks for the tutorial. I'll be doing the same thing as well.
gunz4me is offline   Reply With Quote
Old 08-23-2012, 05:32 PM   #8
zmfc
Member#: 327159
Great tutorial. hope to do to my next car when i get it.
zmfc is offline   Reply With Quote
Old 09-15-2012, 01:27 AM   #9
goloch
Member#: 301391
2012 WRX
WR Blue
First of all, thanks to the original author - brilliant find!
Just did this as part of my JVC HU install and discovered a potential problem.
It seems that the length of the USB cable attached to the Hirose connector affects power to the USB device. I left significantly more cable than shown above and only some of my devices are recognized through the console USB to Hirose hack. Devices with no cables or short cables (USB drives, JVC BT adapter) work, but long cables (iPod) do not.
However, everything was recognized if connected directly to the HU's rear USB. I suspect it's a power problem over the USB extension. I'm going to take it out in the morning and shorten the cable to see if that fixes it.
goloch is offline   Reply With Quote
Old 09-18-2012, 12:57 PM   #10
goloch
Member#: 301391
2012 WRX
WR Blue
Shortened my original 2 ft cable down to 4 inches and everything works great now. Short cables definitely seem to be a must!
Old 01-22-2013, 07:28 PM   #11
wrx777sti
Member#: 283042
2011 Impreza 2.5i
World Rally Blue
Thank you MtnXfreeride,
I will be doing this mod in a very short time and I am so glad I found your writeup.
I was wondering how to do the same thing with the AUX port in the armrest box ?
Any idea anyone ?
Thanks
wrx777sti is offline   Reply With Quote
Old 02-22-2013, 04:04 PM   #12
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Any idea anyone ?
Thanks
There is a guy on this forum who sells the adapter for the 3.5mm jack. I believe its user SVXdc - PM him and ask. He sells these adapters I show here premade too for a higher price.
Also, to the person above who said the long JVC HU cable paired with this doesnt power their iphone:
My JVC headunit has that long USB cable and I have no issues charging and powering my iphone which sits in the armrest all day/night as an MP3 player. (I dont use it as my primary phone anymore). So maybe its your JVC HU that isnt putting out enough power - or the wire you used is too thin.
Old 03-03-2013, 08:58 PM   #13
TheSTIuation
Member#: 327644
2011 STI
MtnXfreeride,
Is that the KW-NT800HDT? If so, I just picked up that unit. Question for you, can't I just run the USB already connected to the JVC to the arm rest and replace the USB that was there previously or do I need to order that connector? I have an 11 STI.
Mark
TheSTIuation is offline   Reply With Quote
Old 03-03-2013, 09:31 PM   #14
TheSTIuation
Member#: 327644
2011 STI
Originally Posted by TheSTIuation View Post
MtnXfreeride,
Mark
Oh and I apologize in advance for my lack of knowledge on this situation. First time going aftermarket.
Old 04-27-2013, 11:33 AM   #15
Haptic_
Member#: 354731
2013 WRX HB
Plasma Blue
Can we use any USB cable for this? I have a lot of ipod cables I don't use anymore and I prefer to keep my micros.
Haptic_ is offline   Reply With Quote
Old 04-29-2013, 10:38 AM   #16
del_tron
Member#: 277736
2006 Saab 9-2x Aero
I don't know if the wires are the same inside an iPod cable.
del_tron is offline   Reply With Quote
Old 08-11-2014, 01:35 PM   #17
fastfive09
Member#: 169597
2011 WRX Sedan
Sorry for my lack of knowledge here but where does the other end of the cut up USB go? I'm assuming you chop the plug part and solder it to the wire harness somewhere?
Can someone tell me if I am completely wrong?
fastfive09 is offline   Reply With Quote
Old 10-10-2014, 03:36 PM   #18
fastfive09
Member#: 169597
2011 WRX Sedan
no one?
Old 10-10-2014, 04:10 PM   #19
travishardiman
Member#: 400123
2014 XV 5-speed
Ice Silver Metallic
There is a $4 adapter plug linked in the first post that the cut USB cable gets wired to. Then the adapter plug goes right into the subaru plug in the vehicle, and the other regular usb male plug goes into the back of the new head unit.
(although for it costs $5 for shipping? so $9 total?)
Or for about $10 you can get one premade that really requires no cutting from SonicElectronix:
http://www.sonicelectronix.com/item_...AX-SUBUSB.html
Or ebay:
http://www.ebay.com/itm/like/181427740600?lpid=82
I got mine for $12 from SVXdc (scroll down to Retain Factory USB Socket):
http://ae64.com/aftermarket-HU-install-parts-IX2012.htm
travishardiman is offline   Reply With Quote
Old 10-31-2014, 07:02 AM   #20
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
yeah that part didnt exist when I made this tutorial, thanks for the link to it.
Old 11-03-2014, 07:05 PM   #21
fastfive09
Member#: 169597
2011 WRX Sedan
Oh Silly me. My current head unit is a cheapy that has no rear USB. I intended to run behind a tablet but I am now having second thoughts.
Am I right in assuming that this does not work if your HU only has front USB?
Thanks for the responses folks
