Old 07-10-2012, 09:57 PM   #1
expo9091
Member#: 249359
Default 07 STi 6262 EFI Logics tuned - 401whp/363wtq - pump gas
Event: dyno pull
Ambient Temp: ~75-80?
Elevation: not sure
Weather: sunny, warm to hot
Car: 2007 STi
Tuner: Chris
Dyno Info: mustang
Transmission: factory 6 speed
Target Boost: 21 psti
Target AFR: 11
Fuel: 93- pump
Engine/Power Modifications:
cobb accessport v2
PTE 6262
treadstone rotated kit
manley pistons
manley turbo tuff rods
arp headstuds
acl bearings
BC 272's
BC springs
BC valves
mild port/polish
killer b oil pickup/baffle
aeromotive pump
ID 1000's
perrin rails
perrin FMIC
omni 4 bar map sensor
aem iat sensor
invidia n1 race
agency power UEL header
Driveline Modifications:
act 6 puck
act streetlight flywheel
fortune auto coilovers
megan trailing arms
car labs x brace
expo9091 is offline   Reply With Quote
Old 07-10-2012, 11:28 PM   #2
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Looks fun, safe and reliable like you didnt push it on 93
jdpsearcher is offline   Reply With Quote
Old 07-11-2012, 08:02 AM   #3
fourmicah
Member#: 128760
2015 STI
Looks good! Is the 6262 journal bearing, ball bearing, or does it come in both?
fourmicah is offline   Reply With Quote
Old 07-11-2012, 08:04 AM   #4
expo9091
Member#: 249359
It's the ball bearing. But it does come in both.
Old 07-11-2012, 08:20 AM   #5
JayMeagher
Member#: 187911
03 WRX
Redish
It's not often I get to say this... But nice job on posting real world numbers. Looks like you don't play the CF game.
JayMeagher is offline   Reply With Quote
Old 07-11-2012, 03:11 PM   #6
expo9091
Member#: 249359
haha thanks, just posting what i have, no need to play with numbers to make myself feel better
Old 07-11-2012, 07:17 PM   #7
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Just curious but are you still on the MAF setup?
C J is offline   Reply With Quote
Old 07-11-2012, 07:34 PM   #8
ParkedWRX
Member#: 286101
'11 WRX
re-read the parts list and ask your self that question again.
ParkedWRX is offline   Reply With Quote
Old 07-11-2012, 07:39 PM   #9
expo9091
Member#: 249359
nope full speed density
Old 07-11-2012, 07:51 PM   #10
ovielito
Member#: 209200
Might want to bring up that boost. 400hp is child's play for that a 30r would've been better with little to no lag.
ovielito is offline   Reply With Quote
Old 07-11-2012, 08:22 PM   #11
expo9091
Member#: 249359
I told them I wanted it safe for now. I'm going back for a meth retune in a few months so I'm hoping to break 500 on their dyno. Also my cams were dying off so I have to think about possibly getting different cams : /
Old 07-11-2012, 10:12 PM   #12
C J
Member#: 132587
2006 JrTuned STi
[email protected]
yeah I see the IAT and MAP sensor now
thanks for the response, I have the same kit and have had nothing but trouble with the treadstone intake MAF placement and ended up buying a KSTech intake.
Old 07-11-2012, 10:23 PM   #13
expo9091
Member#: 249359
It is in a stupid position. Another issue I am still having is no matter what I do I can't get the oil drain line perfectly straight (as i heard precision turbos are pretty fussy with needing the oil drain straight) and the turbo smokes pretty good at full throttle. I'm debating just grabbing a gtx35r for when I go get retuned : /
The build quality of the kit is pretty good, but I liked open dump and I asked if they could weld the recirc dump tube closed and they said " we can't make that modification" lol so I just took it to a local place to get it welded shut and had them make the dump tube a little longer.
Old 07-11-2012, 10:51 PM   #14
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Yeah that would be a nice turbo upgrade, I am using a GT3582 but definitely no smoke under WOT. Also dumping my wastegate as well, just had a buddy weld the recirc closed as well.
Old 07-11-2012, 11:25 PM   #15
IAMDABROODWICH
Member#: 306280
Solid-looking torque curve you've got there. It must hit like a train when you get on it.
IAMDABROODWICH is offline   Reply With Quote
Old 07-11-2012, 11:30 PM   #16
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
What is the hotside for the 6262?????
272 cams should pull to 7500rpm if your hotside is large enough....
Old 07-12-2012, 03:19 AM   #17
expo9091
Member#: 249359
omg it does haha i love it, cant wait to put meth to it and up the boost
chris said they fall off at 7100-7200 (if i remember correctly)...kind of regret getting the BC's now = (
and the hotside is .82
Old 07-12-2012, 05:59 AM   #18
Layvon
Member#: 195711
STi 04/05/06/07
Nice build. A lot of similar parts to what I'm going to have on mine also... Major difference is that I'll use E85 vs 93+meth, but good to see some base lines that are reasonable.
I've got the cosworth 278/274 cams so that might hurt me a bit down low, but I also went with the twin scroll version to help that problem out. I also rotated my intake manifold for that reason.
When do you think you'll be going back for a final tune?
Layvon
Layvon is offline   Reply With Quote
Old 07-12-2012, 06:12 AM   #19
expo9091
Member#: 249359
Layvon
Nice. I wish e85 was more readily available in my area. Closest station is 40 miles away -_-
Eventually I would like to go rotated manifold but ATM I don't have my own place and the apartment complex doesn't let your work on your car in the parking lot. So I'm stuck driving back and forth to my parents which is 60 miles away haha. But hopefully house hunting with the wife at the end of the year.
Final tune might not come till late fall as I'm taking 9 credits at a local college, working full time, an doing USAFR.
Your cams I think will be great up top though. Kinda wish I didn't cheap out on the bc's.... Yea well you live and learn.
On a side note. I read that you can replace cams without pulling motor anyone know of any truth to this??
Old 07-12-2012, 08:16 AM   #20
LBell05STI
Member#: 305890
2005 STI
I've heard its possible but extremely hard to do due to space. I wouldn't even want to try tbh.
LBell05STI is offline   Reply With Quote
Old 08-02-2012, 06:11 PM   #21
expo9091
Member#: 249359
Thanks, I might just pull the motor in the fall. I'll see what happens lol
Old 08-02-2012, 08:32 PM   #22
NateLS1
Member#: 132380
2004 WRX
rojo
You can replace them by slightly tilting the engine to whatever side you are working on.
But it doesn't take too long to pop the engine out either.
NateLS1 is offline   Reply With Quote
Old 08-02-2012, 09:00 PM   #23
expo9091
Member#: 249359
I'll probably just pull the motor. Seems the easiest. Plus i did it like 3-4 times now lol. Now just have to figure out how to change cams. Lol.
Thanks again for the help guys.
Old 08-05-2012, 02:01 AM   #24
evokiller89
Member#: 190916
2005 HTA sti
CGM
Lmao 400 with a 6262, my boy made 370 withva blouch 2.5 on 23psi. If ur gonna be happy with numbers like that but an hta3076 youll make the same numbers and pick up 6-800 rpms of spool
evokiller89 is offline   Reply With Quote
Old 08-05-2012, 02:24 AM   #25
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
^^ lol, soooo amusing. I like the conservative tune, this car will be a beast when it gets turned up.
907Bum is offline   Reply With Quote
