Old 07-11-2012, 02:22 AM   #1
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
Default First Data Log
So I finally got around to switching over to an Accessport and figured I should take advantage of the data logging. The only thing is, I'm not real good at reading this data and/or making adjustments.
I was hoping someone could take a quick glance at the spreadsheet I linked below and see if anything was glaringly wrong. It's a 2008 WRX with nothing done to it, and is currently running the economy map (and getting 31 mpg on the way to work )
Thanks in advance!
https://docs.google.com/spreadsheet/...KYU00aWc#gid=0
boostdsuby8 is online now   Reply With Quote
Old 07-11-2012, 02:35 AM   #2
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
Edit: Finally figured out how to log.
Old 07-13-2012, 12:38 AM   #3
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
Anyone?
Old 07-13-2012, 12:53 AM   #4
chappell943
Member#: 297718
2001 V7 Sti Prodrive
You need to make your log public so I can view it
chappell943 is offline   Reply With Quote
Old 07-13-2012, 08:50 AM   #5
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Thanks in advance!
As chappell943 stated, you will need to go into google docs and make the log public or no one will be able to view it.
Bill
Old 07-13-2012, 10:15 AM   #6
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
Hmm, Google must have changed the privacy setting back when I converted it to their spreadsheet. It should be open access now.
Old 07-13-2012, 10:56 AM   #7
subiebosch
Member#: 155548
2002 impreza outback
2011 WRX TP stg1 +COBB SF
See if you can do a third gear pull and log that. In that log, you are barely making boost at one point and it's less then 1 psi. Its hard to tell anything from the log. COBB can easily show how, there are videos posted everywhere.
subiebosch is offline   Reply With Quote
Old 07-13-2012, 03:48 PM   #8
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
I don't drive it very hard, hence the data. I'll go ahead and post a new log with some positive boost tonight.
Old 07-13-2012, 08:30 PM   #9
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
Here are two logs that have a little bit of positive boost (pulls to 4-5k). I don't intend to drive the car any harder than that on this map. Please let me know if there is anything that I can do to help.
https://docs.google.com/spreadsheet/...yc1BPMEE#gid=0
https://docs.google.com/spreadsheet/...RcVlmd3c#gid=0
Old 07-14-2012, 09:08 AM   #10
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Hi there. There's not much to determine here - there are no issues in your logs as far as using the fuel economy map for its intended purpose. You definitely do not want to do any wide open throttle runs with the economy map - you only did that briefly, however, in the last two logs. Do you ever drive on the stage 1 map? If so, it would be good to log with that reflashed and put the car under some load as described in our logging video below:
Bill
Old 07-14-2012, 01:37 PM   #11
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
^Thanks for the advice. The first log I posted is the hardest I intend to drive on the economy map. I will work on getting a stage 1 log sometime this weekend.
Old 07-14-2012, 11:22 PM   #12
boostdsuby8
Member#: 139739
+'08 SWP
-'03 WRB
That is a great video. Judging by everything I learned there my stage 1 tune is just fine.
https://docs.google.com/spreadsheet/...Wc&hl=en#gid=0
Time for me to do some more reading so I can get a little more advanced with this!
Old 07-15-2012, 10:00 AM   #13
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Your run is a little brief, but looks good.
Bill
Message Board Statistics All times are GMT -4. The time now is 10:20 PM.
