Old 07-11-2012, 10:47 AM   #1
ZeroMOA
Member#: 228127
2002 2.5RS
truck bed liner
Default Green "POWER" light coming on!?!? 02 2.5RS 5spd
I have a 2002 2.5RS 5spd. and yesterday the green "POWER" light came on in the gauge cluster (above the E-brake light). I have called 5 Subaru dealerships and none of the techs have heard of this. Internet results only yield pre-OBDII automatic transmission codes. PS fluid is good, charging system is good, car is running and driving fine. I hooked up my scan tool and it doesn't read any codes. I am perplexed. Any suggestions? Anyone else experience this?
ZeroMOA is offline   Reply With Quote
Old 07-11-2012, 06:33 PM   #2
bakaichi
Member#: 301619
2009 2.5i Hatch
Dark Grey Metallic
Its telling you... it need more power up upgrades...
kidding..
sorry cant help you on this one .
hope some one can chin in on some advice ~
bakaichi is offline   Reply With Quote
Old 07-11-2012, 08:12 PM   #3
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
the owners Manuel will shows what all the lights on the dash mean... flip through it and double check because ive never head of a green "POWER" light for a non turbo suby lol
subiidude is offline   Reply With Quote
Old 07-11-2012, 09:20 PM   #4
strychnine
Member#: 316108
^ Nope. It certainly doesn't.
subaru.com > contact us
they usually get to you in a day or two.
Also I'm fairly sure cross posting isn't allowed. Probably on the other forums you posted on too.
strychnine is offline   Reply With Quote
Old 07-11-2012, 10:56 PM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
used to have a bugeye, never saw such light...
Old 07-12-2012, 07:14 AM   #6
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
I know exactly what light your talking about, and right beside it is and amber 'manual' light? Do you have a 'manual' push button on the side if your shifter?
Duvanator is offline   Reply With Quote
Old 07-12-2012, 07:15 AM   #7
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
I had a 1990 Subaru legacy with the 4eat which had that
Old 07-12-2012, 09:18 AM   #8
ZeroMOA
Member#: 228127
2002 2.5RS
truck bed liner
I am not allowed to post the same question to multiple communities?
NASIOC rules do not apply to RS25 or DirtyImpreza or any other site. Cross-posting only applies to the different forums within NASIOC (eg. "Motorsports" & "General Community")
also, thanks for the subaru.com suggestion, humorously, that didn't cross my mind
Old 07-12-2012, 09:19 AM   #9
ZeroMOA
Member#: 228127
2002 2.5RS
truck bed liner
not an automatic
Old 07-12-2012, 09:25 AM   #10
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
I have this light on my JDM cluster. It doesn't turn on though....
EDIT: according to a forester website and the google machine, the light is for automatic transmission codes.
If you have a manual, just remove the light
Psychoreo is offline   Reply With Quote
Old 07-16-2012, 09:34 AM   #11
ZeroMOA
Member#: 228127
2002 2.5RS
truck bed liner
nah, i'm gonna rig it so it's always on. I like power
Old 07-16-2012, 07:52 PM   #12
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Just a thought: if it is on and it isn't normally something that should be on in your car there is a chance that a couple of pins on your ECU are shorted together that shouldn't be (moisture maybe). Just a guess thought. My dad was working on a ford focus once and the scanner tool was showing a bunch of turbo-based errors and sure enough he unplugged the harness to the ECU and a bunch of water poured out. let it dry overnight and everything was fine again
Rudgers73 is offline   Reply With Quote
Old 07-17-2012, 01:04 AM   #13
T Wrex--OH
Member#: 179478
2000 Impreza 2.5 RS
Sedona Red Pearl
T Wrex--OH is offline   Reply With Quote
Old 07-19-2012, 09:16 AM   #14
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
Originally Posted by T Wrex--OH View Post
He said it's not an automatic...hence not a 4EAT...unless it WAS one and it was swapped to a manual at some point, then the cluster would still have the light.
zavier is offline   Reply With Quote
Old 07-19-2012, 09:59 AM   #15
scarney1988
Member#: 317760
The thing either had the cluster swapped or the trans swapped it seems like. CarFax the vin and compare miles?
scarney1988 is offline   Reply With Quote
