Old 07-11-2012, 06:24 PM   #1
DerekDaniel
Member#: 254088
2008 Legacy GT
Default A/F learning #1 consistently declining
Hello Nasioc ppl,
Quick question every time I data log my car the A/F learning 1 values is consistently declining. It started at 0 then -1.2, then -2.5 and so forth now it is down to -6.25. What could cause this and should I be concerned?
DerekDaniel is offline   Reply With Quote
Old 07-11-2012, 06:29 PM   #2
itsover9000
Member#: 309498
2012 STI Limited
I'm kind of new to this but i believe if the numbers are negative its adjusting by removing fuel. If its positive numbers its increasing fuel. I would say its decreasing fuel because you might have a intake air leak somewhere in your system.
itsover9000 is offline   Reply With Quote
Old 07-11-2012, 07:32 PM   #3
DerekDaniel
Member#: 254088
2008 Legacy GT
Yeah Thats what I thought so I just ordered a cobb post maf hose. I am hoping my MAF sensor isnt jacked up. I cleaned it the other day safely though just spraying some MAF cleaner on it.
AT what number negative value in the A/F learning does it become an issue with the car?
Also, could this cause the car to stall eventually if it is continues to reduce fuel?
Old 07-12-2012, 09:23 AM   #4
Cobb Tuning
Member#: 4803
A/F Learning 1 will vary when driving. There are actually 4 different values that make up A/F Learning 1. When you log that parameter, you are seeing the current one being applied. You can view all 4 individually by looking at the A, B, C, D versions of the parameter. Generally, you should be within +/- 5% for each range, with outside of +/- 8% being a possible problem. You are on the borderline there, but you really want to get a good amount of driving in there since you last reflashed a map, reset the ECU, or disconnected the car's battery (all of which cleared the learned parameters of the ECU).
Positive values mean that the ECU is added fuel due to a perceived lean condition (negative means the ECU is removing fuel due to a perceived rich condition). When MAF sensor go bad, you tend to end up with large positive corrections as you airflow is underreported and you go lean. Intake tract leaks of various sorts can go either direction (generally the same with front o2 issues).
Extreme corrections aren't generally going to cause issues as long as it isn't a bad front o2 sensor. Those corrections are actually most likely helping a car than hurting it because they are getting it closer to where it needs to be fueling-wise (hopefully partially overcoming the effect of the mechanical issue). When they are extreme, though, you really want to get it fixed ASAP. In your case, you -6.25% is borderline. I would continue to watch them and see what happens over time.
Bill
Cobb Tuning is online now   Reply With Quote
Old 07-13-2012, 03:26 PM   #5
DerekDaniel
Member#: 254088
2008 Legacy GT
Default Pulls with A/F learning ABCD
Car 08 Legacy GT auto
Hello I took two data logs with learning 1 and ABCD to see if I have any issues due to the consistently declining A/F learning i was receiving. I tightened some hose clamps, and had a catback exhaust put on. It seems as if the A/F went down on the first pull but the second pull it went back up to -6 range. Bill can ya tell if anything is out of whack and be of concern? Thank you
1st pull https://docs.google.com/spreadsheet/...HZsSEd3NmtQRkE
2nd pull https://docs.google.com/spreadsheet/...2ZWanFlRWVWZXc
Also I took some regular logs and noticed that my fine knock learning has increased to -4.2 now in the 6k rpm range. It never really got in that high rpm range, before I had the catback put on.
These are also my first logs with the catback on. Notice the fine knock learning at the 6 k rpm range was lower on the first pull -1.05 but the second pull was way worse -4.2?? IS THIS BAD? Should I reset my ECU? any advice is greatly appreciated
1st pull https://docs.google.com/spreadsheet/...HNNUVBFb25XZ1E
2nd pull https://docs.google.com/spreadsheet/...XIySi1ZeW1iSnc
Why would my fine knock learning start getting worse? should I reset the ECU and see if it was possibly false knock learned? I just added a magnflow custom catback could that be causing it due to louder noise?
Old 07-14-2012, 08:54 AM   #6
Cobb Tuning
Member#: 4803
Hi - I responded in your other thread.
Bill
Old 09-16-2012, 01:51 PM   #7
uk2006wrx
Member#: 331547
Hello Nasioc ppl,
Did you resolve your negative a/f learning 1 values? What was causing them?
uk2006wrx is online now   Reply With Quote
Old 09-17-2012, 01:58 AM   #8
morgue
Member#: 151596
2004 Wrx
I having the same issue... built leak tester, fixed the few I had, reset ECU and still huge corrections in he A/F learning table.
morgue is offline   Reply With Quote
Old 09-17-2012, 09:43 AM   #9
Cobb Tuning
Member#: 4803
Those are not huge corrections. If you are within about +/-5%, you are fine. Just because they are all trending negative, does not mean there is a specific issue. I would just keep an eye on them over time.
Bill
Old 09-17-2012, 01:43 PM   #10
uk2006wrx
Member#: 331547
How about these then from my stock 2006 wrx!!!
A/F Learning #1:
0 - <5.60 5.60 - <10.00 10.00 - <40.00 40.00+
-14 -13.1 -6.2 -4.7
Can't find cause, any DIY checks?
I have learning view/romraider. I have pulled PCV hoses/oil filler and this swings the trims the other way running lean at idle, so I think the O2 is working ok. I think if I can solve this at idle the other ranges will resolve themselves. New air filter, and cleaned maf wire correctly.
Old 09-18-2012, 09:11 AM   #11
Cobb Tuning
Member#: 4803
A pressure or smoke test of the intake tract would be your first step here to check to see if you have any post-MAF leaks.
Bill
Old 09-19-2012, 12:23 PM   #12
uk2006wrx
Member#: 331547
I've checked all clamps/hoses, and even switched turbo->intercooler hose, admittedly I have nt done a boost leak test as I need to get a compressor and make a kit.
would n't a post maf leak under vacuum, cause positive fuel trims, as the ecu would need to add fuel due to the extra unmetered air?
Old 09-19-2012, 01:10 PM   #13
uk2006wrx
Member#: 331547
I'm curently investigating the o2 sensors as I'm wondering if they are incorrectly reporting rich to ecu.
Should the rear o2 on a 2006 wrx oscilate rich/lean continuously on idle?
Mine seems to stick 0.8V or 0.05v, unless it is reved where it will rise or fall and return.
I've NOT got a CEL or any fault codes. I'm using romraider logger graph to monitor.
Old 09-20-2012, 09:25 AM   #14
Cobb Tuning
Member#: 4803
Yes, but you can also lose metered air due to a boost leak, which would cause you to run rich and see negative fuel trims. A pressure/smoke test should always be your first test when you start seeing extreme fuel trims as post-MAF leaks are very common problems and they are the easiest (and typically cheapest) to fix compared to other possible problems like a bad MAF or front o2 or other mechanical fueling related issues.
The rear o2 only generally has limited authority over fueling and will only impact the closed loop fueling target. It has nothing to do with your long-term fuel trims related to A/F Learning 1, which is entirely due to feedback from front o2.
Bill
