Old 07-12-2012, 02:22 PM   #1
Highflyr
Member#: 289162
2012 WRX
PBP
Default 2012 WRX 93+AEM Stage 1 datalog. Do I need HWG map?
I was wondering about going to the HWG map. I seem to be only able to get about 16.5-17psi on average. Thanks for the help.
https://docs.google.com/spreadsheet/...JTjZJVEE#gid=0
https://docs.google.com/spreadsheet/...0NHNLQ3c#gid=0
Highflyr is offline   Reply With Quote
Old 07-12-2012, 05:22 PM   #2
Butterz
Member#: 21205
2004 WRX Wagon
Brown
This is a tough call. You're not undershooting boost by very much at all so I'd be concerned that the HWG map could potentially push you too high. The map notes state that you should be within +/- 1.5psi of target boost and technically you are in that range. If you do decide to use the HWG map I definitely recommend keeping an eye on boost through live data to make sure you don't see anything too high.
Butterz is offline   Reply With Quote
Old 07-13-2012, 09:40 AM   #3
Cobb Tuning
Member#: 4803
You are underboosting enough that the HWG map would benefit you, but I would take additional logs after you reflash it to see how things look.
Bill
Old 07-13-2012, 11:55 AM   #4
Highflyr
Member#: 289162
2012 WRX
PBP
Bill
Thanks for the help guys.
