Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-12-2012, 08:27 PM   #1
turbo970
Member#: 325644
1992 legacy
Default 1992 legacy no spark
bought a 1992 subaru legacy turbo wagon with the 2.2. and this thing wont start unless you leave it sit a long time. replaced coil ign module plugs wires and still no spark. could it be the timing belt that jump or crank position sensor. it have 1200 in this car and it has only 103,000 on it
turbo970 is offline   Reply With Quote
Old 07-12-2012, 09:04 PM   #2
damonmlime
Member#: 54525
2000 00rs 2x91ss 95l
blue ridge pearl
Is the cel on? Try the coolant temp sensor. Could also be the MAF sensor. If you hold the gas pedal to the floor when you're trying to start it and it starts it's probably the MAF.
damonmlime is offline   Reply With Quote
Old 07-12-2012, 09:10 PM   #3
turbo970
Member#: 325644
1992 legacy
i can have the pedal floored and nothen. but i let it sit a week and it fired up idled til i put it into drive and push the pedal and it died and wont start. and the check engine light is on showing a code 45. but wont erase after i replaced the part
Old 07-12-2012, 11:29 PM   #4
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
If this is the case then the wiring is at fault somewhere. Check the pressure sensor connector for proper power and ground. OBDI codes should not be present unless the sensor is damaged or not getting proper power and ground.
As for the no spark issue, test for proper power and ground at various ignition components such as the ignition relay, iginter, coil pack and see if you can come up with anything.
Jessekrs123 is offline   Reply With Quote
Old 07-13-2012, 11:37 AM   #5
turbo970
Member#: 325644
1992 legacy
so this could be a ground issue?
Old 07-13-2012, 03:25 PM   #6
turbo970
Member#: 325644
1992 legacy
and if it is a ground issue how many grounding points does this car have
Old 07-13-2012, 09:46 PM   #7
damonmlime
Member#: 54525
blue ridge pearl
Lots of ground points. Sometimes the coolant temp sensor won't throw a code but is bad. What is code 45?
Old 07-13-2012, 10:34 PM   #8
turbo970
Member#: 325644
1992 legacy
Old 07-14-2012, 12:14 PM   #9
turbo970
Member#: 325644
1992 legacy
heres the car
Old 07-18-2012, 04:36 PM   #10
turbo970
Member#: 325644
1992 legacy
bump i need help
