Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 07-12-2012, 10:42 PM   #1
SSP6
Member#: 260374
2002 WRX wagon
Default worn out turbo?
so this is really eating me up. i installed my injen FMIC, and injen intake and ran stg 2 which cobb stated wouldnt make a huge difference in. (i know i need a pro tune, however i have made the proper minor changes with ATR to make the car liveable until i get up north for a solid tune) post install it wouldnt hit target boost, i did alot of trouble shooting and found 2 small boost leaks, fixed them, adjusted my wg act. arm tried both HWG and Std tunes and im still off about 2psi give or take. it runs really well and the FMIC made a really big difference in intake temp and overall performance, so im happy, but its not what it should be. i'm oly seeing a repeatable 15.9-16.1 at wot. no knock, DAM 16, no codes except an occasional missfire at idle/warming up. i'm not running out of fuel, my inj dutycycles are still well below 100. i keep the car well maintained. im wondering if the turbo is just maxed out and tired, having a tough time filling all the extra piping. my targets are always 17.8. do i try a manual boost control and see if it'll do it and then go after the ebcs? lil help, thanx
SSP6 is offline   Reply With Quote
Old 07-13-2012, 09:48 AM   #2
Cobb Tuning
Member#: 4803
Do you have a 3rd gear WOT log that you can post? The FMIC is well outside the scope of the OTS map and the car will need to be tuned. The intake you are running is also not compatible with the OTS map which can potentially cause serious fueling as well as ign. timing errors. It would have be tuned for using a wideband o2 sensor. There is the potential for engine damage when using the wrong intake for a given map. I would at least verify fueling with a wbo2 before attempting to achieve more boost.
Bill
Old 07-14-2012, 10:05 PM   #3
SSP6
Member#: 260374
2002 WRX wagon
as stupid as this sounds, i'm having trouble creating a document. you are absoultely right though, as an OTS map really has no place with my setup. i was trying to wait on a pro tune until i get my 16g-xt and 850cc injectors to get the most from my money. thanx for the input, i'll shut my mouth and quit bitching about 2psi.
