Old 07-13-2012, 09:50 PM   #1
jrmsti
Member#: 103675
Default ej20r engine harness help
anyone have pinout chart for a ej20r engine harness for the 2 grey connectors or wiring schematic/diagram from it, i only have the engine harness and want to come straight into this with my standalone harness, i believe it should be the same as a ej20k minus the coil on plug wiring the ej20r has
jrmsti is offline   Reply With Quote
Old 10-17-2012, 03:07 PM   #2
jrmsti
Member#: 103675
bump ttt
Old 10-17-2012, 03:30 PM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
I've never seen R wiring posted anywhere easily found on the surface web.
I used to want to get one, but then the lack of resource made me go G/K.
If you're running wasted spark with your standalone, go with a K wiring setup. I happen to have one.
If you're COP with your standalone, it's time to strip the R harness down to each individual wire and go to town!
eg33GC is offline   Reply With Quote
Old 10-18-2012, 05:55 PM   #4
jrmsti
Member#: 103675
Yeah I started unlooming everything to check continuity with a multi hopefully everything goes well
Old 10-18-2012, 05:57 PM   #5
jrmsti
Member#: 103675
do you by any chance have the dash harness from a ej20k?
Old 10-18-2012, 08:25 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
no just engine
Old 10-19-2012, 09:24 AM   #7
suberdave
Member#: 101865
88 GL-10 STi
how many plugs are on the ECU? 3 or 4?
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 10-23-2012, 03:11 PM   #8
jrmsti
Member#: 103675
ecu is a 3 plug
-=Suberdave=-
