Old 07-14-2012, 03:48 AM   #1
Jarrod164
Member#: 253937
1995 WRX
Default No brake pedal!
So I drove to work downtown today and later at night I turn my car on and get ready to leave... no brake pedal whatsoever!
Popped the hood and noticed the fluid in the reservoir is lower. I was under the hood yesterday and thought that my fluid level dropped a bit. I think it dropped 1cm or so over the last 24 hours.
So I was e-braking home until I realized pumping the brakes over 6 times restored some braking power. But it immediately lost braking power if I let go for a few seconds.
Topped up my brake fluid as one friend suggested, the level was still above the low marker line when this all started so it hasn't run dry. A guy with wrx happened to pull over and take a peek, thought maybe my master cylinder was gone. Except I'm not leaking fluid into the cabin.
I'll bleed my brakes as a starting point I guess.
Any help is majorly appreciated.
Jarrod164 is offline   Reply With Quote
Old 07-15-2012, 10:42 AM   #2
jonthesloth
Member#: 184390
1999 Forester
GREEN
Bleed the system indeed. What would really help you is the Motive Power Bleeder or something to pressurize the system to see if it holds. If you don't have anything like this, then check your Master, your ABS module and check all the lines that connect to the calipers and to the hard metal lines in the wheel wells.
Something isn't right, and if bleeding the system of air doesn't fix your problem, then you know what the next step is.
jonthesloth is offline   Reply With Quote
